Tail lamp fuse keeps blowing
Old May 14, 2024 | 02:21 AM
vqgwap's Avatar
Fun
Fuse keeps blowing after a short drive and my radio lights go off aswell whenever it blows, is there some stuff i should try doing?
Old May 14, 2024 | 04:21 PM
05_SkylineSedan's Avatar
20 Year Member
Is your "high mounted brake lamp" in a rear spoiler? If so, check the wiring which passes through the rubber boot from the car body into the trunk lid. You can pull that rubber piece back from either end and check for frayed or shorting wires there. That's a known trouble spot because every time you open the trunk those wires get bent back and forth.
I wouldn't think your radio lights would be on the same circuit but I can't look that up right now. Gotta get your brake lights working!
Caleb Tanner
Dec 11, 2020 12:20 PM
DEMoLITIoN
Lighting
Sep 14, 2015 12:16 PM
JJs G
DFW G35 Owners Club
Jul 28, 2014 06:50 PM
NjMatteSedan
Aug 10, 2009 01:09 PM
