Push Button Start
Originally Posted by SLVRG35
Basically you'll connect the push button to a relay, then the relay to Ignition(2 connections), ground, and starter. It can be done with any push button switch & a relay.
Hmm...that doesn't look that bad at all. When you tap into the cig lighter, are the starter wires close by? Do you rememeber what colors they were? Yellow with Red?
on
so i dont get the point, you still hve to put the key in and turn it, then hit the button??? theres no point, if all cars came factory like that, people would want the key to do the whole procedure in one turn as they do now. its more ergonomic. push button start is a great feature when you have a key fob, but if u still have to put the key in the ignition and turn it, it seems kind of ricey. there is just not point and no conveinence factor this way
