Push Button Start
Old Dec 14, 2005 | 12:57 AM
Dan_K's Avatar
Push Button Start
I am thinking of adding a push button start from the M35/45. Could someone tell me what items I would need to complete this project? Also, I'm pretty sure I would need some drilling/cutting of my dash parts in order to mount the button. How hard is it to do this or could I pay some company to do this for me?
Thanks for any info.
Old Dec 14, 2005 | 01:59 AM
manh3's Avatar
bump
Old Dec 14, 2005 | 03:08 AM
mrjonang's Avatar
Doesn't the intel key do this? push start or something similiar to this?
Old Dec 14, 2005 | 08:37 AM
Dan_K's Avatar
The '05 sedans and '06 coupe/sedan have the inteligent key. The older models don't.
Old Dec 14, 2005 | 08:46 AM
chilibowl's Avatar
The 06 coupe/sedan intelligent key loaded are only the AT's, and theyre not push start, its still a twist , u jus dont have to put the key in
Old Dec 14, 2005 | 11:18 AM
B GrAzi's Avatar
i should have got an 06
Old Dec 29, 2005 | 07:43 PM
SLVRG35's Avatar
I have this
Attached Thumbnails Push Button Start-ignited1.jpg   Push Button Start-ignited2_2-2-.jpg
Old Dec 29, 2005 | 10:03 PM
tararan's Avatar
slvrg35 - is that OEM or aftermarket. if OEM what year is your car? thanks..
Old Dec 29, 2005 | 10:25 PM
SLVRG35's Avatar
its aftermarket, made by Ignited. I took out the cig lighter and used the opening in the panel, fit perfect.
Old Dec 29, 2005 | 10:31 PM
Hooman6MT's Avatar
20 Year Member
Originally Posted by SLVRG35
I have this
Do you have any sort of write up, or something that you followed? I'm sure many people here would be interested in doing this. (Me included) Thanks!
Old Dec 29, 2005 | 10:33 PM
SLVRG35's Avatar
yeah I guess I could do that, might be a day or two before i get a chance
Old Dec 29, 2005 | 10:36 PM
Hooman6MT's Avatar
20 Year Member
no prob. Whenever you get a chance. A wiring diagram is all that we really need. I just want to know the correct wire to splice and put the switch between. Thanks!
Old Dec 29, 2005 | 11:03 PM
SLVRG35's Avatar
Basically you'll connect the push button to a relay, then the relay to Ignition(2 connections), ground, and starter. It can be done with any push button switch & a relay.
Old Dec 29, 2005 | 11:05 PM
luongdmd's Avatar
will this work on an 04 coupe? if so, what would i need and do you know who could do this in sol cal?
thanks
Old Dec 29, 2005 | 11:09 PM
SLVRG35's Avatar
It should work on any year vehicle, not sure of anyone in SoCal, I'm in Missouri. Its pretty easy to do, 4 connections , no more than 1 1/2 ft from the button
