Hawaii Honolulu
Test Pipe Question
Old May 25, 2006 | 03:43 PM
gwasabi's Avatar
Test Pipe Question
Ok so I am planning on either buying a kinetix or labree resognated test pipe. Do you think that it will look like a cat because of the resognator? I know it's illegal but I heard some guys take off the cat cover and put it on a test pipe to make it look like it's still there. I was planning to do this.
And what is a 02 bunge or something like that.......
Old May 25, 2006 | 04:26 PM
XLR8SN's Avatar
It wouldnt really matter. If you know vehicles....you can tell by the sound that there are no cats in a car. Also by the smell of the high unburnt gas content in the exhaust.
The O2 bung hole is a port where the O2 sensors connect to. Those sensors monitor the O2 levels and adjust the engines timing and such to adjust for the low or high gas content in the spent fumes.
Depending on the year of the car, the CEL will illuminate because of the high gas content in the exhaust. You might need to do that mount adjustment to "trick" that sensor.
Old May 25, 2006 | 10:22 PM
gwasabi's Avatar
so if I were to go in for recon it wouldn't pass right? well i'll just put it on after i get a recon when i get my body kit. I have a 06 will the CEL light up? I don't know of the trick. I tried searching but it never really says how to do it. Something about a spark plug or something?
Old May 25, 2006 | 10:29 PM
sen_jen's Avatar
Meatshake Enterprise
correct. you wouldn't pass recon with it. you would also fail safety check. yes, your cel will light up on the '06. go to sonics and tell them to take care of it. usually known as the simulator.
Old May 25, 2006 | 10:45 PM
DHCrocks's Avatar
it's a spark plug non-fouler. you need to drill it out and install it between the pipe and O2 sensor. pm if you need a set. I bought a couple when I did mine so I have an extra set collecting dust.
Old May 25, 2006 | 11:18 PM
636Racer's Avatar
IMO, test pipes suck. I have'm installed on mines, I'm just to lazy to change them out.
Old May 26, 2006 | 01:12 AM
Xile's Avatar
I second that! I have them installed on my 05 as well. I have the APS one's with the brackets.....and my check engine light is on. Maybe you should consider buying high flow cats instead. I've invested enough time and money on test pipes that would have paid for a nice pair of high flow cats by now.
Old May 26, 2006 | 04:49 AM
gwasabi's Avatar
so if i went for recon and safety how would they tell its atest pipe? wouldn't they be like oh look it looks stock whatever lol I dunno i've never gotten recon sorry if i sound stupid
Old May 26, 2006 | 05:45 AM
636Racer's Avatar
You dont need recon for saftey check unless it's a suspension mod, then a saftey inspection station may request recon. I should know, I was worried about my test pipes at first, but even in the recon books, it doesnt specify the need for recon with exhaust for safety. What saftey inspection places might check is whether or not the exhaust system is too loud.
Old May 26, 2006 | 02:34 PM
gwasabi's Avatar
well I do have suspension mod but it's such a small drop noone notices. It's only about an inch drop. I just wanted to know if I would get caught with it if I go for recon when i get my body kit
I'm also wondering if the kuruma Z front bumper, kenstyle sides and rear bumper will pass recon? I'm pretty sure veilside type 1 wings wont pass.
Old May 26, 2006 | 06:02 PM
rev-01's Avatar
** senjen posting from rev-01's ps **
it's good to know that safety check doesn't check for exhaust smells/test pipes.
gwasabi:
from what i was told this morning: kuruma z, kenstyle sides/rear will pass recon so long as the quality of the fitment is good. as long as nothing is removed behind the bumper (e.g. "small" metal bar!!), you're good to go. however, you need to mount the front license plate on the kuruma z. as for the rear, as long as the support on the rear isn't removed, you're good to go.
Old May 26, 2006 | 07:45 PM
gwasabi's Avatar
is it illegal to mount the front liscense plate to the side like offcentered kind?
I feel like a newb asking these questions sory. I don't really know alot about this. I have asked around and I have searched but I get different things everytime.
Thanks for all the help. I'll be at the sunday cruise so I might ask for some pointers then.
G35VSHNG37
Oct 25, 2015 08:43 PM
Ray Feta
Aug 13, 2015 11:40 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
