Hawaii Honolulu
waterspot removal
Old Aug 19, 2006 | 11:51 PM
DTR_Projekt's Avatar
waterspot removal
what do you guys use to get water spots off your windows?
Old Aug 20, 2006 | 12:03 AM
636Racer's Avatar
mx7 and extra fine steel wool. I forget the grit number...but it should be the finest one.
Old Aug 20, 2006 | 09:18 AM
Diesel1's Avatar
Moderator
#0000
Only problem is some guys have said the steel particles rust. Someone mentioned bronze wool or brass wool once on autopia as an alternative I think.
I just tried the diamondite glass system on my car. I had some water etching that I wanted to fix. I would grade this stuff as a B. Bad spots needed multiple applications. I think I would grade it higher if the stuff was cheaper. It is kinda pricey.
I have also picked up some glass shower door water spot remover from Home Depot for the shower doors, and that stuff worked great (On shower doors). Much easier to use too and cheap! I forget the name, but it is a powder that comes in a small yellow rectangular bottle. I think it has a red top. I picked up a sponge in the smae aisle with a whiteish scrubber on one side. The stuff cleaned the shower doors spotless in seconds! I should have used that on the G windows!
Other guys have also used vineagar to remove spots as well. If you look on autopia, you'll find all the info you need!
Old Aug 20, 2006 | 08:28 PM
EndlessNA1's Avatar
Go to ACS theres this waterspot removal thing in a white bottle with a green label. Works really good. I think its a local brand too.
Old Aug 22, 2006 | 03:17 AM
Thanks endlessNA1! I went to matco and picked it up. It's a Malco product....$20 bux a bottle! But it is gaurenteed to work, or your money back from matco!
Old Aug 22, 2006 | 08:50 AM
EndlessNA1's Avatar
No prob bob. I just remember my friend Kolu got that for my NSX and worked miracles.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
