Hawaii Honolulu
Does chaing my own oil void the warranty?
Old Dec 31, 2007 | 04:55 AM
jdm-v35's Avatar
as the title says.. can I still retain my warranty if I do my own oil changes?
Old Dec 31, 2007 | 12:29 PM
BSOMTHIN's Avatar
i dont think the stealer ship is that sensitive
Old Dec 31, 2007 | 01:56 PM
bruddahmanmatt's Avatar
Sure we are. I mean we are a STEALership as you so eloquently put it after all. Some people.
To the OP: from what I understand, changing your own oil does not void your warranty...UNLESS...unless something goes wrong with your vehicle and it's determined that the underlying cause was you changing your own oil (i.e. you didn't properly tighten your drain plug and it flew off on the H3 causing you to dump oil all over the place and you ended up running your car for 30 miles with no oil and your motor seized blah blah etc...). If like most REAL MEN (j/k j/k ) you know how to change you own oil, you'll be fine.
Basically anytime you do your own work or outsource it to someone outside of the dealership, from what I've been told, if your/their work is the cause of any mechanical issues, it's debatable as to whether the job is covered under warranty. Honestly the best thing to do, is simply call service and ask them. Retarded speculative comments like the one made above do nothing to help your situation. Just call and ask man. Our service department is pretty chill.
Old Dec 31, 2007 | 02:11 PM
Bigd2k6's Avatar
it shouldn't. just save all your receipts.
Old Dec 31, 2007 | 02:57 PM
jdm-v35's Avatar
sounds good! thanks matt. BTW do you work at the infiniti in mapunapuna? thats the one Ig ot o since I live like 3 miles from there.
Old Dec 31, 2007 | 03:46 PM
Yesm. Ask for me too. I like see your car.
Old Dec 31, 2007 | 05:48 PM
636Racer's Avatar
just make sure that the oil you're goimg to use has the API certification. otherwise there is the possibility that it will void your warranty. this is why a lot of dealerships won't honor some cars that use amsoil. their most advertised oils don't have an API Cert. until recently they have been marketing an API cert grade. just keep in mind that dealerships don't frown on diy oil changes...just the type of oil (synthetic or regular)
Old Dec 31, 2007 | 11:33 PM
jdm-v35's Avatar
yea I only use royal purple with greddy filter. also, are you on the sales floor?
Old Jan 1, 2008 | 03:36 PM
Yep.
Old Jan 3, 2008 | 03:40 PM
tdm racer's Avatar
Keep really good records on when you did your oil changes and also save ALL receipts. Getting warranty voided or coverage denied due to lack of maintenance records would suck.
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
