Hawaii Honolulu
RIMS WITH BREMBO BRAKES
Old Jul 18, 2004 | 04:30 AM
jdbinspired's Avatar
Was going to purchase some ADR MSPORT 19X8.5 front and 19X10 rear with a 35 offset from Ebay. I was told by a local dealer that the wheels will not clear the Bremo Brake's... Not sure if the guy wanted me to buy rims from their shop or what... Any suggestions on the type of rims/brand that would fit on the G35 Coupe with the BREMBO BRAKES??
Old Jul 19, 2004 | 03:52 AM
GZire's Avatar
Re: RIMS WITH BREMBO BRAKES
Check the wheels/tires/brakes forum on this site. You can also check Tire Rack & Rays Wheels websites.
Old Jul 19, 2004 | 02:02 PM
XLR8SN's Avatar
The offsets are not just the issue. On some of the rims the actual rim design is not condusive to fit the larger protruding Brembos. You will need to watch what type of spoke design you choose. However the offset of 35 might be a little too much if they are for the rear. If and when you plan to drop the car,...depending on the type of coilovers you choose (should you go that route), the flange of the coilover will possibly cut into the side wall of the tire.
You could run spacers, but that probably is not the best idea if you can help it.
Just my thoughts...
sinasajadi
Aug 26, 2015 04:12 AM
Popes
Jul 29, 2015 05:07 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
