Hawaii Honolulu
clicking sound
Old Feb 14, 2005 | 06:14 PM
aznracer's Avatar
clicking sound
ok this is weird im getting a clicking sound from some were and i cant figure it out i think it might be a wheel barring for all these puddles out here. any one else getting this ???? any ideas i checke my sway bars and they were all torqued to spec still so o dont know
Old Feb 14, 2005 | 10:35 PM
sen_jen's Avatar
Meatshake Enterprise
^ take it to the dealer and see Mr. Jason Tokunaga (srvc.advisor). there is a bulletin regarding this issue. if it's proved to be what the bulletin says, you'll have it replaced.
you might want to check all the suspension bolts as well if you've lowered your car.
Old Feb 15, 2005 | 08:52 PM
aznracer's Avatar
not lowered just sway bars
Old Feb 15, 2005 | 09:03 PM
XLR8SN's Avatar
Check the TSB section in the forums. But here are a few links.
https://g35driver.com/forums/brakes-suspension/9531-suspension-click-noise.html
https://g35driver.com/forums/tsb-technical-bulletins/43865-link-all-g35-tsb-s-date.html
There has been issues with the axel and other things as well.
Rather than diagnosing it yourself though...probably better to just take it to Infiniti and allow them to inspect the problem. If it is indeed a TSB issue, it will be no charge to you anyhow.
It will be on record that you had them look at it as well, in case there is another issue associated to the current issue.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
