- FS: Cobb Accessport (03-06 Coupes/04.5-06 Sedans)
- WTB: Haltech Platinum PRO Plug-in
- FS: AVC-R Black limited (never used) AEM Meth Kit.
- FS: HKS Twin power DLI
- FS: Haltech Plat pro PNP
- ******LOOK..HKS Twin Power DLI Ignition Amplifier.. $325 shipped *****
- FS: Hypertech Power Programmer 2003-2012
- FS: ProEfi 48 w/guage, E85, and wideband
- FS: UpRev Osiris Tuner + a STOCK ECU!!!
- FS: Haltech Pro Harness 350z/G35 with all cables
- FS: 2006 6MT RevUp ECU and complete engine harness
- FS: Utec with Map Switch/Maf Sensor
- FS: Betty's Garage 8 gauge grounding wire set
- FS: Cobb Accessport AP-NIS-002
- FS SoEast: oem front o2 sensor
- FS Texas: Uprev Cipher Cable
- WTB: Grounding kit
- FS: Black Betty Grounding Kit
- FS NorEast: Aem Fic
- FS: Grounding Kit and Denso Spark plugs
- FS: Haltech Plat Pro
- FS: OEM MAF sensor off 2004 G35
- WTB: 60mm Defi BF fuel pressure gauge and sensor
- WTB: Uprev Maf Sensor
- 2004 MT g35 ECU
- WTB: Used ECU wire extension harness
- FS: APEXI Super Airflow Converter and Actuator Valve Controller Type-R
- WTB yaw sensor aka gravity sensor
- FS: Optima Yellow Top (Deep Cycle & Starting Battery)
- WTB: Hypertech Max Energy Sport Power Programmer - 62005
- FS: infiniti G35 jet performance air flow sensor
- Brand New SxExCx Custom Grounding Kit
- FS: Haltech Platinum
- FS: NC- G/Z Unichip plug and play cheap $180 shipped
- WTB: Piggy back/fuel system
- buddy club e controller
- HPX PMAS MAf
- Camshaft and Crankshaft Sensors 23731 6J90B & AL60C
- FS (UT): Osiris Standard Cable
- HKS EVC 4 Electronic Boost Controller
- Apex-i SAFC 2 Super Controller
- KP Technologies No Lift Shift Module
- Wtb: battery cover rubber trim coupe
- HKS DLI2 ignition w/ Harness
- FS: NEW HKS Turbo Timer - Type 1
- FS: HKS F-Con Piggyback ECU - Fuel and ignition plus harness
- SxExCx Grounding Kit (red)
- Apexi AVC-R boost controller
- FS: Unichip with custom tune $275 Shipped
- FS (UT): Uprev Cipher Cable
- FS: Uprev Osiris Standard
- WTB complete 6mt engine harness
- FS: Uprev Cipher Cable no Licenses
- FS: SxExCx Grounding kit (RED)
- WTB: Turbo timer
- WTB: SxExCx Grounding Kit
- FS: UTEC with Map Sensor and Map Selector
- FS: HKS Twin Power Ignition Amplifier
- Brand New HKS AF gauge with 2 O2 sensors
- FS: Brand New Haltech with Dual wideband AFR and Boost controller
- Intake valve timing control solenoid (VTC)
- wtb sprint booster
- Uprev Cipher Cable
- Wtb: 6mt de ecu
- Osiris Uprev Tuner
- Osiris Uprev Tuner Version
- spark plugs
- FS (SoCal): SxExCx Grounding Kit in Red
- FS: 03/04 BCM & Master power window switch
- FS: Brand new NGK Platinums
- 04 g35 sedan starter NEW (not oem)
- *****wtb cyber speed voltage kit!!!!!!*****
- Defi BF Boost-Fuel-Oil & Control Box & Turbo XS Utec
- FS. 2003 g35 de engine harness
- FS. 2005 G35 A/C Compressor
- FS.2005 G35 Throttle body
- WTB 1 coil pack
- FS: Aem wideband, Defi 30psi boost, Haltech, Apexi AVC-R
- WTB HKS DLI 2 ignition
- WTB: 05 Engine Harness and ECU 6 speed
- WTB: Hypertech Programmer
- WTB 04 G35 Coupe MT
- HKS FCon VPro + Navigator
- WTB EVAP Purge Control Valve
- Camshaft Position Sensor 23731-AL61A - Brand New Nissan (Driver' side/angled)
- WTB: 05-07 Ipdm!
- WTB: 6MT DE Engine Wiring Harness and ECU
- WTB! Throttle body
- Greddy Boost Gauge, HKS Turbo kit
- FS: (MS) SxExCx Grounding kit [RED]
- FS: Haltech Ecu
- BNIB One step colder NGK Spark plugs
- ****Black Betty custom grounding kit****
- FS: UPRev Osiris Standard (w/ cable)
- Haltech E11v2 Ecu
- FS: Odyssey 34-PC1500 Battery
- Brand New High Gauge Cables - Blue F/S
- FS (UT): SxExCx Grounding Kit- Black
- FS (UT): Osiris Standard Cable- Unmarried
