Hit a Huge Rock & Tire Blew Out
Old Apr 17, 2014 | 05:32 AM
pbabajan's Avatar
i have all kinds of lights on now after having put on a donut.
vdc, slip, abs are all on
just wondering if this is normal or if i should be worried.
seems like something is going on with my brakes too. if i slam on them they feel horrible.
feels like bad grinding.
i dont see how the brakes could have gotten affected by the rock.
Old Apr 17, 2014 | 07:04 AM
Urbanengineer's Avatar
Did only one wheel hit? I'm imagining more hit and one that isn't the donut is out of round.
Old Apr 17, 2014 | 09:56 AM
mathnerd88's Avatar
If you hit a rock with a tire, all associated components around that area could be damaged. It doesn't happen all the time, but it does happen.
Your brake lines could be severed, the rotor could be damaged, the abs line could be ripped out of the socket, etc. Your brake fluid may be leaking...
You should get it checked at a mechanic to make sure.
Also, since this happened after you put the donut on, you might have put it on the wrong way. Can you take it off and put it back on and make sure nothing was caught in between? The bad grinding noise could be the ABS functioning even though your tire has traction, which means your ABS may have an issue.
Old Apr 17, 2014 | 04:17 PM
pbabajan's Avatar
Ouch hopefully none of that happened but I have a bad feeling. Lol
Thanks for the quick reply guys. I'll take it in to see what's up and update on what happened
Old Apr 17, 2014 | 04:21 PM
pbabajan's Avatar
Oh yeah, I'm pretty sure it was only one wheel that got affected at all
Old Apr 18, 2014 | 07:03 AM
ra1nman's Avatar
Last week I hit some road debris on the highway after looking over my shoulder. Ended up with a dent on oem factory 17" and a blown sidewall. I put my doughnut on and drove on it for at least 3 days maybe 80 - 100 miles without any issue.
On a side note, I ended replacing the single tire with the same make mode and tread depth however different speed rating. I know it isn't recommended but I haven't noticed any unusual noises, dash lights, or anomalies.
Old Apr 22, 2014 | 02:22 AM
pbabajan's Avatar
i ended up getting a used tire for now til my new comes in and it is back to normal dont know what happened
Sepsis
Feb 12, 2020 02:05 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
derres
Aug 28, 2015 03:27 PM
EasySausage
Jul 14, 2015 11:17 PM
