Anyone Clean their MAF (mass air flow sensor)
Old Aug 15, 2007 | 10:14 AM
  #46
da mayor's Avatar
cleaned the MAF helps pretty well.... i have to do the throttle body soon
Old Aug 25, 2007 | 01:10 AM
  #47
Mad Paradox's Avatar
J-Dizzle
Doing this tomorrow
Old Aug 25, 2007 | 01:28 PM
  #48
_jb's Avatar
_jb
Photographer
Glad it's helping you guys.
It's one of the few cheap things you can do that makes a real difference.
Old Sep 15, 2007 | 12:22 PM
  #49
abunai's Avatar
ok i went out and got that CRC mass air flow sensor cleaner and im cleaning mine right now... Autozone is full of idiots!!! i asked for the MAF cleaner and he tried to give me carb and choke cleaner?!?!?!!? wtf! so i told him it would fck up my sensor and he looked puzzled so i drove down to Pep Boys and found it right away... Autozone Blows!!
Old Sep 15, 2007 | 01:03 PM
  #50
Beebo's Avatar
im going to try it i hope i dont screw up lol
Old Sep 15, 2007 | 01:25 PM
  #51
abunai's Avatar
it was actually really easy... kinda hard to screw anything up. i just hope it helps my gas mileage out
Old May 20, 2009 | 01:20 AM
  #52
ar9080's Avatar
89000mi and mine actually looked relatively clean...cleaned it with an alcohol prep pad, we'll see. Been using a K&N for about 40,000mi. was a BIOTCH to remove, surprisingly had the weird star-shaped screwdriver that fit, but had to unscrew many things because the angle was so awkward.
Old May 20, 2009 | 08:04 AM
  #53
Blue Dream's Avatar
I drove ttrank's car solo
You must really be searching to find this thread. Good job!! Good info for a lot of us noobs on the MAF!!
Old May 21, 2009 | 01:19 PM
  #54
Jeff92se's Avatar
Red Card Crew
Those star things are called Safety Torx bits. They can be found at most auto stores for cheap. I recommend getting a set. Handy
I used alcohol and a Q tip. GENTLY
Old May 21, 2009 | 01:58 PM
  #55
_jb's Avatar
_jb
Photographer
I posted a picture up about five or six posts in this thread...
-jb
Old Sep 7, 2009 | 01:25 AM
  #56
cubs4worldseris's Avatar
I know this is an old thread, but i searched and this came up. It has given me a great amount of information. Thanks for that DIY writeup JB. One question, I know you have to relearn the throttle body sensors after cleaning. Do you have to relearn anything after cleaning the MAF or does the MAF sensor readjust itself (example: fuel mixture)?
-David
Old Sep 7, 2009 | 04:53 AM
  #57
blaccG35's Avatar
im thinking bout doing this and i was wondering do you spray the opening in the 1st pic or do you just spray the MAF sensor???
Old Sep 7, 2009 | 05:29 PM
  #58
OCG35's Avatar
-David
no re-learn procesdure for MAF sensor
I’m not sure which pic you are referring to – but you don’t really even need to remove the sensor – you can simply unbolt the housing (and unplug off course) and spray the sensor while in the housing… the stuff evaporates very quick.
Old Sep 7, 2009 | 06:19 PM
  #59
blaccG35's Avatar
ohhh k thanks OCG
Old Sep 7, 2009 | 10:36 PM
  #60
Ya thanks OCG, i just did the MAF clean and while at it, i took apart the whole intake system and cleaned everything (except for the MAF housing tube). I also threw in a K&N High Flow. Prior to the cleaning, the car was idling at 1.15k RPMs and after the clean the car was down to 850 RPMs at idle. I haven't taken the car out for much of a drive, but once i do i will report back to you guys. Next project is the throttle body cleaning.
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
derres
Aug 28, 2015 03:27 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
