Crawford Cat Install
Old Jul 17, 2006 | 08:19 AM
speeddreamz's Avatar
Ok so i've done plenty of cat installs and exhaust work on other cars, but I haven't on the G. Im doing crawford cats, finally got all the bolts and gaskets together (they were used). I looked under the car and it looks fairly complicated to switch them out. I was thinking a number of diff methods but can you suggest any? Here goes mine:
Remove intake tube, use super long impact extension to shoot off the nuts facing up (on both sides of course). Then get under car, shoot bottom nut. Disconnect harness and Y pipe. Then go ahead and disconnect the 02 sensors.... any particular way to get um out? The heatshields seem to be in the way as far as I can tell. I haven't seen a flare wrench in like size 21 or whatever the o2 sensor is...
Old Jul 17, 2006 | 07:52 PM
GReddySetGO's Avatar
I did the whole thing from the bottom. The stock cats are a b!tch to get off. Just cuz the upper most bolts are so hard to gain access to.
Old Jul 18, 2006 | 08:53 AM
LMG_35C's Avatar
Couple of threds in the DIY section. Seems most prefer getting to the Cats from the top - two people make it easier.
Best to disconnect o2 sensor connectors, drop cats, and then remove them. o2 sensor socket (sears) is best way to prevent damaging those expensive units. I think they are 21 or 22mm but the DIY thread has corect size.
Let us know how it goes...
zoop425
Mar 29, 2016 05:51 PM
Th611
Oct 27, 2015 03:48 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
