HELP!!!header vibration!!!!!!
Old Aug 3, 2006 | 07:33 PM
KesterG's Avatar
Hey guys...or gals
i just install crawford header and hf cats today, but when i accelerate or turn, i can feel the engine is vibrating.
the installation guy showed me that the header is almost attached the vent.(i would say more than 1 cm and less than 2 cm)
therefore, its the header caused the vibration (feel like metal is rubbing metal)
does anyone has this problem?
need help!!!!!!!!!
great thanks!!!
Old Aug 3, 2006 | 08:29 PM
UFGatorG35's Avatar
Hey bud, not sure if I know what you mean by "attached the vent", but there is almost NO room between the headers and the firewalls in the engine compartment. Some people recommend bending the AC line slightly to get it farther from the header, but I never had an issue with it. The headers and cats will make a decent amount of rasp, but if your block is actually vibrating more than ususal your shop most likely screwed something up with the engine mounts putting everything back together. Other than the rasp I had no more vibration than before. Let me know if this helps.
Old Aug 3, 2006 | 09:07 PM
ballisticus's Avatar
Disconnecting engine mounts for a header install + "Zero Room" between firewall = bad
Should have bought headers that fit right. Might want see if Doug will take them back so you can get some DC sports or Alphaworks.
Have heard plenty of issues with the Crawford HF cats rubbing on the heatshield too. Some people have solved it by beating it with a hammer. Again, I think I would just get some cats that fit right.
Old Aug 3, 2006 | 09:13 PM
UFGatorG35's Avatar
The headers do fit just fine, I had them on my car and have several friends who have had or still have them. Yes it is snug due to the diameter of the pipe, but in no way does it "not fit". Like I said, it sounds like the shop did not install properly for this to happen.
Kester, do you know if the shop used the instructions from Crawford, or did they just try to squeeze the headers in without lifting/tilting the engine block?
Old Aug 3, 2006 | 09:17 PM
KesterG's Avatar
hey man
yeah
i told them to use the instruction from crawford.
i am not sure if its rasp sound or vibrating, but i definitely feel something is rubbing from my engine bay
(when i do quick acceleration and turn)
Old Aug 3, 2006 | 09:22 PM
UFGatorG35's Avatar
Originally Posted by KesterG
hey man
yeah
You will definitely hear rasp, especially when you jump on the throttle. Have you watched how close it gets (have someone rev it while you lok down at the side of the headers) under high rev?
Old Aug 3, 2006 | 09:27 PM
KesterG's Avatar
no i havent..
i will go to my bodyshop next week and let him check it again.
he is buzy tomorrow and monday is holiday in vancouver....
i will ask my gf to rev and i will check it.
thanks man!!!
thank you for your help!!!!
otherwise, the header is amazing.
i luv it!!!
Old Aug 3, 2006 | 09:30 PM
UFGatorG35's Avatar
no i havent..
thanks man!!!
i luv it!!!
See if she cant help you right away, just in case something was done wrong. Let me know what you find out, I'll see if anyone else has heard of it.
Old Aug 3, 2006 | 09:38 PM
KesterG's Avatar
i will find out this weekend if the header is hittin the vent.
and let the shop checks it again.
i will let you know when everything is fine.
i will keep you update.
thank you
Old Aug 4, 2006 | 12:33 AM
Do you like the Alphaworks you have on the car now better than the Crawfords?
Old Aug 4, 2006 | 12:54 AM
UFGatorG35's Avatar
I would honestly say the Crawfords had a better sound but couldnt say about the power - they were on an 04 and the Alphas are on an 05. The 04 definitely pulled more, but I never had them dynod. I wanted to keep the Crawfords but got tired of asking my shops for favors on the install/uninstall because of the time involved.
Old Aug 4, 2006 | 03:00 AM
99atlantic's Avatar
the shop fvcked up the install.
Old Aug 4, 2006 | 06:21 PM
KesterG's Avatar
hey man
i ask someone tried to rev the engine when i watched the header.
i did not see any vibration or anything rasp sound.
only when i drive the car
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
magnetism80
Jan 27, 2016 12:57 PM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
