help air hissing noise when putting on intake
im puting on my stillin intake and Z tub. but ive ran into a problem, when i went to take of the A/C line bracket for the bottom mounting point of the air box, air started leaking from up by my radiator and i cant get it to stop. please help!
Originally Posted by 04smashin
Damn thats exactly what i was afraid happened. well wont infiniti fix the leak and give me a freon recharge under warrenty.
put all the OEM intake system back on the car and take it to Infiniti.. should get it done under warranty... gotta be more careful next time
ya if your going to bring it to Infiniti hoping to get it done under warranty then you need to make sure you put all the OEM stuff back in and make it look like you wernt messing with stuff in there.
try to make it look like some vibrations from the intake tube made the bolt mess up the ac line. Once you get it fixed. You should cut a rubber tube and cover the line near the airbox.
I would highly suggest putting back all the FACTORY and taking it into the Dealer to see if they'll cover it under warranty???
Just throwing out blind suggestions, but you never know...
rezendvous420
May 31, 2020 01:26 PM
