Fast Intentions (Metallic CATS) Installed!!!
Old Aug 28, 2006 | 02:47 AM
  #31
FastIntentions's Avatar
Originally Posted by ekwc
Is it come with the new gaskets, nuts and bolts?
The gaskets are needed for sure. Nuts and bolts are better to have, since re-using the old ones might not be as good (rusty).
They come with all new hardware, and new 2 bolt gaskets. You will reuse your stock 3 bolt gaskets...Tony
Old Aug 28, 2006 | 10:00 AM
  #32
pdjafari's Avatar
here's a clip of what mine sounds like...
http://ebaumsworld.com/bubbrubbvideo.html
Old Aug 28, 2006 | 12:54 PM
  #33
killerlexus's Avatar
repost
Old Aug 31, 2006 | 10:09 PM
  #34
ekwc's Avatar
Is it a CARB OBDll COMPLIANCE CAT for the Ceramic and/or Metallic version?
Will our cars pass the emission test after replacing the cats?
Thanks.
Old Sep 1, 2006 | 09:58 AM
  #35
rcdash's Avatar
were the HP gains posted above for the cats alone?
and will it pass a sniffer test? and OBDII test?
(I'm know it's not been emissions certified or anything - just wanna how much trouble it'll be to pass inspection each year here in NC)
Old Sep 4, 2006 | 11:29 AM
  #36
The ceramic cats will pass a sniffer in most states, all depending how strict your smog testing is. Its 50/50 if they will pass the sniffer in California, but we are extremely strict. The Metallic is more of a race cat...Tony
(No they are not OBDII compliant.)
Old Sep 11, 2006 | 03:36 AM
  #37
Jining's Avatar
Whats the difference in gains ceramic vs metal?
Old Sep 11, 2006 | 09:33 AM
  #38
ISMSOLUTIONS's Avatar
1-2HP...not much really.
Rick
Old Sep 11, 2006 | 12:58 PM
  #39
LMG_35C's Avatar
Tech article in this month's Import Tuner says metallic cats are better for FI applications where you need to run very "rich." Ceramic decomposition is accelerated in this mode.
In general they reported no real HP/TQ improvements with HFC's over today's OEM... then again they were testing a Honda.
Old Sep 12, 2006 | 12:37 AM
  #40
It is true that Ceramic CATS could get soaked and have problems - Fast Intentions cannot warranty any CATS that are put on FI's for Nitrous cars, or other highly modified cars, as they can and likely will cause premature failures due to running too rich or lean. The Metallic CAT will be the longer lasting of the two in this case.
Rick
Gip
Aug 24, 2015 05:31 PM
linedr89
Aug 17, 2015 05:11 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
