N/A - headers a yes or no?
Old Sep 23, 2006 | 02:25 PM
  #46
jaspergtr's Avatar
Originally Posted by lowrider
Crawfords are the only True Equal Length header. The others try to come close, and do. But they are not true equal length, nor do they claim to be.
Lou
are you sure? did you see the links i had posted earlier, from dc, and stillen?
seems they are claming equal length tubing to me... unless you know something that's not posted directly from the company.
Old Sep 25, 2006 | 07:22 PM
  #47
5150DS's Avatar
Does anyone know what cats, if any, are CARB certified.
Old Sep 25, 2006 | 10:08 PM
  #48
4DrSkyline's Avatar
Originally Posted by ChiefyMan
What exhaust do you have 4DrSky?
Fuji exhaust for the sedan.
As far as companies other than Crawford claiming that their headers are equal length, I'd be curious to know what part of the header their measuring. There clearly is a volumetric different between the various pipes on all other headers other than Crawford, which should determine how long it takes the exhaust gases to get to the collector area. Just because you can measure the outside distance on one of the pipes, the inside distant on another, and they measure out to the same length does not make them equal length!
That kind of misadvertising is right up there with "This stainless steel cat-back exhaust system will increase your sedan's performance by 21-23 hp and 21-23 lbs ft. of torque - at the rear wheels!". That quote was taken directly from Stillen's website. If they had at least said, "We saw a gain of 22hp and 22tq at the wheels on our dyno.", then it wouldn't be as bad as their above statement. If I don't see those types of gains, can I get a full refund, including shipping costs both ways? Hell, no! I just wish companies would advertise more accurately.
Fortunately for Enzyte, their product worked. Otherwise I'd be griping at them too.
jk
...rant over...
Old Sep 25, 2006 | 11:18 PM
  #49
ISMSOLUTIONS's Avatar
Many cats are CARB legal - but OBDII is what has to be complied with...and you'll find none other than your stock CATS...
Rick
Old Sep 26, 2006 | 05:52 AM
  #50
markiev37's Avatar
I just orderd a set of DC headers along with some kinetix hi flow cats and mrev2 and 5/16 isothermal plenum spacer!!! Oh ya, unichip tune to tie it all together everything goes on in about two weeks....
Old Sep 26, 2006 | 01:25 PM
  #51
_jb's Avatar
_jb
Photographer
THAT should make a difference!!!
Do you have a link to the unichip you're talking about?
Old Sep 26, 2006 | 05:28 PM
  #52
jaspergtr's Avatar
awesome! don't forget to post results.
Old Oct 5, 2006 | 08:37 PM
  #53
99atlantic's Avatar
Originally Posted by diablo1356
ive heard doing all the normal exhaust mods excluding the exhaust is a really good setup...supposedly the stock exhaust flows pretty good and adding in a TD or a larger pipe will cause a big low end power loss...99atlantic is running the I/H/HFC and says he has no power loss but all gain...anyone wanna shed some light on this...ive heard it many times and im in the process of purchasing a stock exhaust to try it out...
still running with the stock exhaust (I think i did my headers in april if i recall right?) and still havn't noticed any losses anywhere in the curve. I still stand by it's the larger exhausts that cause people down-low loss
Old Oct 6, 2006 | 08:31 AM
  #54
markiev37's Avatar
Car goes in the shop this tuesday(10-10). I will have a pre install dyno and a post install dyno to show my results and i'll post them up. The tuner shop out here ordered the unichip for me......
magnetism80
Jan 27, 2016 12:57 PM
alessandro
Oct 8, 2015 09:29 AM
lavtxa
Sep 21, 2015 11:51 AM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
