Short Ram intake for an 06 Coupe
Old Sep 15, 2006 | 09:54 PM
MastaRip's Avatar
Ok ive been trying to research alot on which intake i should get. I live in florida where theres puddles almsot everyday, especialy during hurricane season so forget about a cold air intake, im looking for a short ram. I need a suggestion on which brands are good, i heard injen is good but cant find any short ram intakes made my injen. Can someone please tell me whats good, a good brand and anything else i should know for precaution. Also if theres an install guide can someone hook me up Thanks alot for all the help
Old Sep 15, 2006 | 10:18 PM
Diamond G35's Avatar
Z-Tube and K&N drop-in....save $150!
Old Sep 16, 2006 | 12:38 AM
TURBOTOM's Avatar
a.k.a kleicoupe
I had the z-tube/popcharger setup. now i have the stillen, i say get the stillen and a ztube.
Old Sep 16, 2006 | 12:44 AM
ZeRo G35's Avatar
I'm sure this have been discussed many times on other threads but how beneficial is the z-tube with a drop-in stillen intake is compared to the others? I was also doing some research on some short ram intakes but after researching, I realized that many of the members on this forum uses the z-tube.
Old Sep 16, 2006 | 12:48 AM
abcquackyxyz's Avatar
yup ztube.with stillen or popcharger..i like both of them
Old Sep 16, 2006 | 12:59 AM
norcal_chan96's Avatar
I have the injen intake and customized it for the winter...Took off the long tube and bought a weapon-r filter.... Here are some pics.... But i'd have to say i'd rather have stillen because i have to keep changing the long tube in the winter... BUT injen sounds awesome at WOT w/ the longer intake tube...
Like my red NOS lines... LoL... Not to get off topic... Grounding wires don't do ****! ! !
Attached Thumbnails Short Ram intake for an 06 Coupe-g35-engine-bay-pics-005-internet.jpg   Short Ram intake for an 06 Coupe-g35-engine-bay-pics-009.jpg
Old Sep 16, 2006 | 01:07 AM
MastaRip's Avatar
wtfs a z tube is it like a shirt ram or cold air and can water get in the engine with it?... sorry if i sound noobish heh
Old Sep 16, 2006 | 01:13 AM
The Z tube is pretty much the upper intake tube... If u can see on my pic it would be the shinny injen tube; that is wat a Z-tube looks like... And water can get into anything, but it's alot harder to do with a Z-tube and pop charger... Just watch ur driving.... Injen and AEm have a higher risk to get hydrolock...
Old Sep 16, 2006 | 01:15 AM
bull3t's Avatar
what kind of grounding kit is that? never seen one set up like that
Old Sep 16, 2006 | 01:17 AM
Hyper Grounding System...
Old Sep 16, 2006 | 01:25 AM
I have this secret i did with the injen intake... I bought the weapon-r filter and connected a tube to the end of it so i can get ram air...(Got tube at Kragen's) Then Zip tied the tube to the bottom left air duct to help air flow... I dont know if it has helped ...
Attached Thumbnails Short Ram intake for an 06 Coupe-point.jpg   Short Ram intake for an 06 Coupe-g35-engine-bay-pics-003.jpg
Old Sep 16, 2006 | 01:48 AM
^ well its more efficient with cold air...but not sure about possibly keeping the water from coming up.
Old Sep 16, 2006 | 02:22 AM
zeroscythe's Avatar
u know those type of tubes create air turbulence(spelling?) which cause uneven air flow to go thro the intake, throwing off your MAS which is responsible for reading how much air is going in and match it with fuel... if ur getting choppy readings caused by air turbulence u could be loosing power...
the inside of the tube is kinda like this ^^^^^ and as air passes over those ridges it gets all uneven and choppy... it may sound bas *** because of the huge amount of air being put into the system but in some cases maybe not urs it can cause a powerloss... research something called an air sheild they sell a kit for it at autobacs, it composed of flat surfaces to prevent that problem...
Old Sep 16, 2006 | 02:32 AM
I dont think it's that big of a problem... I think it helped out... I ran a 13.9 with the tube... Before it a 14.0... SO... That can tell u right there... Plus the trap speed was higher...
Old Sep 16, 2006 | 04:28 AM
Silverbolt's Avatar
Yeah, if I had a set up like that, I wouldnt drive through waterfalls anymore... and no more racing submarines
In order for him to suck water with that setup and filter, hes going to have to have the amount of preasure of a jet engine turbine! lol!
