crawford high flow cats
Old Sep 21, 2006 | 09:09 PM
lowrider's Avatar
Originally Posted by abcquackyxyz
visual inspection i dont think you would pass..but sniff i think you could...Crawfords are nice cats...but dont they rattle??
Visual would be a crap shoot. IMO, they look enough like a stock cat on some vehicles, that the inspector might get fooled into thinking they were OK. The stock cats on my 2006 GMC Sierra are actually smaller than the Crawfords.
Lou
Old Sep 21, 2006 | 09:14 PM
techi13's Avatar
^ i believe most hfc rattle, thats why you gotta get an engine dampner...
the older crawfords were know to rip and tear where the brackets are (under the cats) and i believe an engine dampner will help with that also
Old Sep 22, 2006 | 03:15 AM
abcquackyxyz's Avatar
Fast intentions dont rattle, thats what i heard.. they dont have any heat shield to bother with..and they have great clearance.
Old Sep 22, 2006 | 03:40 AM
Greatwars's Avatar
I have Crawford and no, it doesn't rattle .... how do they do inspection in NYC? didn't they just test the *** from your exhaust (that's what they do in Cali)? It should pass if that's the case (hfc still has the catalytic).
Old Sep 22, 2006 | 03:43 AM
In cali i heard you get caught with visual and sniff....but if you know your mechanic then its all okay...i hope...But the guys at FI told me that it wont pass visual cause it will stick out like a sore thumb...and instead of 4 cats there are only 2 cats with the HFC's i dont know where to go about with that one though.
Old Sep 23, 2006 | 04:15 AM
Greatwars's Avatar
Ya, I'll say depending on your autoshop .... I didn't go to dealer though... I went to a mexican autoshop and he would do anything to make you pass (at least in my area --ole day)
Old Sep 23, 2006 | 12:34 PM
ISMSOLUTIONS's Avatar
Originally Posted by lowrider
The function of a cat is not to quiet the vehicle although it does alter the sound and quiet the car, but to reduce emissions. It is not packed with a stranded material like fiberglass or steel wool. They have media in them that is supposed to scrub the exhaust. They are filled with a metal catalyst, usually platinum, rhodium and/or palladium. That is why the cost so much.
Lou
High flow cats are not packed with stranded materials. They are honeycomb shapes mazes that are designed to heat the exhaust to an extreme point to burn off gasses and clean the exhaust.
They are made of ceramic cores or metallic cores, and the metallic cores are rolled, but still in a honeycomb shape/pattern.
Check here https://g35driver.com/forums/intake-exhaust/112899-fast-intentions-metallic-cats-installed.html Post #11...
Rick
Rick
Old Sep 23, 2006 | 02:04 PM
techi13's Avatar
so will hfc pass the emmisson part of the test?
Old Sep 24, 2006 | 01:06 AM
Maybe yes and maybe no...every car is different and so are the mods we all do on them. The best chance you have at passing a sniff test is with Ceramic 400 cell CATS.
Rick
Old Sep 24, 2006 | 01:27 AM
techi13's Avatar
i guess i'll find out in 5 years
Old Sep 24, 2006 | 01:37 AM
Just save your CATS and swap them in for the test and back out again...
Rick
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
vamarris
Sep 26, 2015 12:56 PM
