Tune question
Old Sep 28, 2006 | 12:51 PM
maicoJr's Avatar
Tune question
Is the UTEC user friendly or should i pay a pro to do this?
Old Sep 29, 2006 | 11:54 AM
ISMSOLUTIONS's Avatar
If you truly know what your doing and have A/F gauge and bung - you can do it yourself...ANY doubt and have a pro do it and watch closely and learn.
...Rick
Old Sep 29, 2006 | 01:01 PM
maicoJr's Avatar
Thanks
Does anyone know of anyone that can tune my car in the chicagoland area or of a way to find someone to tune my car.
Old Sep 29, 2006 | 02:35 PM
SuperShick's Avatar
what's a bung?
Old Sep 29, 2006 | 02:38 PM
Originally Posted by SuperShick
what's a bung?
A bung is an additional O2 nut for screwing in wideband and other sensors for tuning abilities and monitoring.
Old Sep 29, 2006 | 04:52 PM
4DrSkyline's Avatar
Not knowing the chicagoland area, I'd check the listings of dealers on the TurboXS website. Call a few in the area and see if they do tuning also or can make any recommendations for local tuners.
http://www.turboxs.com/dealers.htm
Old Sep 29, 2006 | 08:15 PM
maicoJr's Avatar
Thanks
I found someone that can do the tuning in my area. Do u guys think. I have a 2003 g 6mt and i am planning on getting a MRev2, K&N CAI or Stillen, NGk Iridium plugs. Then in the spring i am getting headers and High Flow cats. Should i wait for the tune until i put in the headers and HFC or do it now and then later?
Old Sep 29, 2006 | 10:21 PM
KenK2's Avatar
The Pole
Tuning the UTEC is really easy.. I wish there was a tuning section here like there is @ my350z.. Anyways, if you want to go the UTEC route, you will have the purchase the UTEC along with the wideband tuner.. It will cost you around $1100 for everything.. YOU WILL have to drill/ weld a bung in your test pipe/ HFC in order to read A/F ratios.. If you do go this route, I can help you with the install and the tune.. I know I am across the Country from you but email, pm's and AOL IM is a cheap way to help peeps out.. you can also hit up the tuning section of my350z and check out all the posts I along with a bunch of other peeps have made regarding the UTEC.. Hit me up if need be..
Old Sep 30, 2006 | 10:54 AM
maicoJr's Avatar
Thanks. When i get ready to do that, i will check the z site and if that does not work, i will definitely contact u.
Old Nov 12, 2006 | 09:40 PM
Luv2xcelR8's Avatar
what is the advantage of a tune? Would I benifit from a tune if I had an HKS Hi-power exhaust on a stock rev up engine? Or the HKS with MREV2 and 5/16 spacer?
-thanks- o and how much is this utec system?
Old Nov 13, 2006 | 09:40 AM
Generally, the advantage is more power due to the fact that once combinations of mods are put on a car, the car needs to be adjusted to get the most HP. The car are detuned to a degree, so you can get that power back with a good tune.
A UTEC runs about $1,000-$1,400 depending on accessories/options you get with it, and where you buy it.
The more mods, the better and bigger the benefit. A simple catback installation does not warrant a tune. Intake, CATS and catback...sure. A stock G can get up to about 15HP off a tune though.
Rick
Old Nov 13, 2006 | 03:07 PM
Luv2xcelR8's Avatar
So if im going to go with a catback exhaust I can get a tune and get some mor horespower? Is this something that is done at a shop? what is the cost generally?
Old Nov 13, 2006 | 03:26 PM
KenK2's Avatar
The Pole
As Rick stated, its not really needed simply for a catback exhaust system, but if you get test pipes, or high flow cats ALONG with he catback exhaust then it would be a good idea..
Ideally, go with full exhaust system (including test pipes) and do some motor work too.. MREV2 and a spacer along with a CAI will yeild some nice gains after the tune.
IMHO, if you just get the catback you wont yeild much with a tune..
Tuning the UTEC costs anywhere around $300-$500. It is very user friendly too so users are able to tune them easily, free
jsimonk
Dec 22, 2023 03:49 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
