TD exhaust or X/H pipe?
Old Oct 12, 2006 | 01:03 PM
Jtrain's Avatar
I maybe going F/I shortly... I know my Injen isn't good enough for F/I...
Would a 2.5 inch X pipe exhaust be better than my Injen... Or do I need 2.5 TD
I only want 400rwhp... do I need the TD?
Old Oct 12, 2006 | 01:09 PM
redlude97's Avatar
An X-pipe exhaust can still be considered a "true dual" there is seperate pipe for each side of the engine, and two seperate mufflers. The x-pipe is meant to decrease pressure variations between each exhaust so the power is even between the two sides. As long as the exhaust is a straight through 2.5 TD design, then it should work regardless of the presence of an X/H pipe.
Old Oct 12, 2006 | 02:10 PM
Jtrain's Avatar
So an EVO 2 Greddy wouldn't be bad for a F/I application?
Old Oct 12, 2006 | 03:02 PM
redlude97's Avatar
I would say the problem with a greddy exhaust isn't the piping, but the slightly more restristive canisters compared to some of the other exhausts. Its canister is much larger and the tip is offset so there will be more restriction compared to some of the other designs, so if you are trying to make the most hp possible with your exhaust on a turbo setup, then the evo2 probably isn't the best choice
Old Nov 24, 2006 | 06:56 PM
350gt man's Avatar
I have an 03 6mt with and intake and was in the market for headers and thinking dc sport headers with the y pipe(downpipe) whatever you call it, anyway what is that best y pipe to go with?
Old Nov 24, 2006 | 07:00 PM
Calvin's Avatar
Overglorified Altima
^^imo the only y pipes worth buying are the JIC and top secret ones
but they are both expensive
ONLY get an after market y pipe if you KNOW you will never go true dual...other wise its a waste of money
Old Nov 24, 2006 | 07:02 PM
350gt man's Avatar
k thanks man
Moskvitch
Sep 14, 2015 10:15 AM
Albanian122
Sep 12, 2015 04:02 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
erich2780
Sep 3, 2015 03:23 PM
