Help with test pipes
Old Oct 27, 2006 | 12:00 PM
YngPhllyKd's Avatar
I just got the UTR Resonated Pipes. Will the check engine light come on once i install them? If so, how do i go about fixing that?
Old Oct 27, 2006 | 07:52 PM
DieselX's Avatar
It probably will... you need a no-fouler spacer thing. Go to my350z.com and search for it, some guy sells it for like $20.
Old Oct 27, 2006 | 08:04 PM
Nismo G's Avatar
Unless the pipes come with a pre drilled hole for the 02 sensor then your warning light will come on.
Old Oct 27, 2006 | 09:59 PM
zazaracing's Avatar
Team Transport Member
As long as you plug your o2's in you should be fine. I never threw a cel for it if it does just do an ecu reset or drive for a couple days and it will correct itself
Old Oct 27, 2006 | 10:08 PM
gary c's Avatar
Test Pipes..............
Here's one good reason to live in Flordia.....you can
get away with almost anything! Here in Ca. we have
the smog cops.....attend something like Hot Import
Nights and they stop everyone.....even being invisible doesn't work.....haha
Old Oct 28, 2006 | 01:32 AM
Calvin's Avatar
Overglorified Altima
yes it should turn on with your 06. i think anything after 03.5 or 04.5 (or something like that lol) will throw a cel. fix it with non foulers
Old Oct 28, 2006 | 11:15 AM
YngPhllyKd's Avatar
can i just go to pep boys or auto zone and pick up a set of non-foulers?
Old Oct 28, 2006 | 11:59 AM
Calvin's Avatar
autozone should have them..search the forums..i know the part numbers have been posted a number of times..or ask "fastintentions" or "ismsolutions" if you cant find the numbers
Old Oct 28, 2006 | 12:01 PM
Calvin's Avatar
here, i found this on my350z.com
you might have to be a member ti view it, im not sure
http://my350z.com/forum/showthread.p...ght=non+fouler
it's a spark plug non-fouler..you need to drill it out and install it between the pipe and O2 sensor..
edit: found what you need..
you'll the the HELP 42002 non foulers - and you'll have to reset the ECU again..then you should be fine again
Old Oct 28, 2006 | 12:13 PM
MixturePinoy's Avatar
i just leave the cel on, brings contrast to the dash
Old Oct 28, 2006 | 12:38 PM
YngPhllyKd's Avatar
I sent him a PM. Thanks for your help!
magnetism80
Jan 27, 2016 12:57 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
Albanian122
Sep 12, 2015 04:02 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
