Which Spacer Should I Get!
Old Nov 2, 2006 | 12:28 AM
kennyz424's Avatar
Okay im going with the 5/16" but which one is better and why...obv the thermal one but why
Motordyne 5/16" Copper ISO Thermal Spacer
This stealth modification adds 11HP-13HP and reduces the effect of power robbing heat soak. The engine cover easily fits and never needs to be cut. With the engine cover in place the engine bay looks completely stock. Use the copper if it ever snows in your area.
Motordyne 5/16" Basic Spacer
This stealth modification adds 11HP-13HP and is the simplest to install. The engine cover easily fits and never needs to be cut. With the engine cover in place the engine bay looks completely stock.
Old Nov 2, 2006 | 12:32 AM
kennyz424's Avatar
http://infinitipa.zoovy.com/category/engineupgrades
Motordyne 5/16" ISO Thermal Spacer
Motordyne 5/16" Copper ISO Thermal Spacer\
wtf man lol there are 3 different ones haha which to choose i have NO CLUE
Old Nov 2, 2006 | 01:10 AM
kennyz424's Avatar
Cmon guys please help me out lol i wanna order these today ... which one should i go for! and why!
Old Nov 2, 2006 | 01:14 AM
filanj's Avatar
here are some pictures of mine off with my kinetix plenum on...
https://g35driver.com/forums/archived-sales/123188-fs-kinetix-racing-plenum.html
Old Nov 2, 2006 | 01:20 AM
kennyz424's Avatar
that doesnt answer my question on which of the three i should buy lol idk the difference between them!
Old Nov 2, 2006 | 01:26 AM
jinubob81's Avatar
Evil Bastard
just buy the most expensive one you can afford.
It is pretty much the best thing to do in this somewhat isolated case.
No joke.
Old Nov 2, 2006 | 01:39 AM
Calvin's Avatar
Overglorified Altima
if it snows where you live. get the copper iso thermal. if not, get the iso thermal.
Old Nov 2, 2006 | 01:43 AM
Calvin's Avatar
also i just read i can keep my engine cover...
Motordyne 1/2" Basic Spacer
This stealth modification adds 12HP-14HP and is the simplest to install. The engine cover easily fits and never needs to be cut. With the engine cover in place the engine bay looks completely stock.
and ...
I guess i can keep my engine cover for the 1/2 correct?
i dont know where you got those quote from..but the engine cover will not fit with the 1/2 spacer
here is the quote directly from the motordyne website:
1/2" Basic Plenum spacer/1/2" Iso Thermal plenum spacer
This stealth modification adds 12HP-14HP and reduces the effect of power robbing heat soak. This plenum spacer can be used for maximum performance enhancement. It also adds a substantially deeper induction growl under the hood.
^^doesnt mention anything about the engine cover fitting
5/16" Basic Plenum spacer/5/16" Iso Thermal plenum spacer
This stealth modification adds 11HP-13HP and is the simplest to install. The 5/16" plenum spacer is fully compatible with all stock and aftermarket strut bars. The engine cover easily fits and never needs to be cut. With the engine cover in place the engine bay looks completely stock.
Old Nov 2, 2006 | 02:03 AM
V35 Skyline GT's Avatar
6MT Coupe
Here's from there site too explaining the difference of ISO and Copper:
ACCESSORIES
Iso Thermal upgrade with Aramid gasket and Coolant Control Valve
Motordyne Iso ThermalT is the most comprehensive plenum thermal management system available. The upgrade will reduce heat transfer into the upper and lower plenum assembly and helps to reduce power loss as the engine bay becomes heat soaked.
Compatible with any type of plenum stock or modified. Recommended for warm climates generally above 45 ° F.
$50.00
Copper Iso Thermal upgrade with Aramid gasket and Copper Throttle Body Heater
Compatible with any type of plenum stock or modified and compatible with any type of weather hot or cold. Copper Iso Thermal also reduces heat transfer into the upper and lower plenum assembly, but the Copper Throttle Body Heater keeps the throttle body heated to prevent ice formation on the throttle body valve on very cold or snowy days. If it snows in your area use the Copper Iso Thermal to keep the TB heated while still take full advantage of the cold dense air for increased HP.
$110.00
Both will work as far as the plenum is concerned. The big difference between the two is if you use their kit on the Throttle Body Heater.
The copper one is recommended for cold climates like where it snows.
Here's that pix you wanted with no cover and oem plenum:
Don't take offense, but if you had read everything on their G35/M35 web page, it explains everything about the ISO and Copper. This is where I posted the above info from.
Old Nov 2, 2006 | 02:19 AM
G-MENTED's Avatar
stick to the iso 5/16. its only a few hp difference. save the drama for your baby mama.
Old Nov 2, 2006 | 03:00 AM
truplay8's Avatar
THE BATMOBILE
1/2.....who cares about your engine cover........or jst get a crawford plenum
Old Nov 2, 2006 | 10:40 AM
papiloco21's Avatar
www.motordyneengineering.com
just read here ^
Old Nov 2, 2006 | 11:12 AM
Steel Blue's Avatar
If this spacer is your only engine mod, will you notice a decrease in low end torque like you would if you added only an aftermarket muffler?
Old Nov 2, 2006 | 11:26 AM
lekker_droom's Avatar
go for the skunk2 5/8" spacer.
Old Nov 2, 2006 | 11:36 AM
  #30
gary c's Avatar
Spacers...........the final frontier
Now that you've heard from all the experts give Tony
a call at MotorDyne. He'll be able to set you straight
on what can or can't be done......661-993-5111. I
have a 1/2" spacer and the factory engine cover will
"not" fit!
