do i need a new gasket for the crawford?
Old Nov 1, 2003 | 09:54 AM
ramo's Avatar
i just ordered the crawford plenum through strictly z and i was wondering if i need to have a new gasket for it? i only have 2500 miles on my car
Old Nov 1, 2003 | 11:16 AM
madisonmc's Avatar
Re: do i need a new gasket for the crawford?
No new gasket is required.
Old Nov 1, 2003 | 11:22 AM
G35Gnome's Avatar
The shop manual says to replace it, but you will be fine with using the current one ... just make sure to be careful with it and not bend when you remove-install the plenum.
Crawford Plenum / Z tube + Stillen Hi-Flow / Borla Dual Exhaust / Stillen Xdrilled+Stotted Rotors
Best 1/4 mile 14.371 @ 100.29, 60ft 2.347
Old Nov 1, 2003 | 09:21 PM
davey2003's Avatar
It's good practice to always use new gaskets. So my answer would be yes use a new gasket.
Old Nov 1, 2003 | 10:23 PM
GurgenPB's Avatar
Just get a new one. For 3.95 can't go wrong. i replaced mine aftert bending the original and having leaks!
Gurgen
Old Nov 1, 2003 | 11:25 PM
zimbo's Avatar
gasket? what gasket? Is this the little black plug that you have to move from the old plenum to the new one?
--Steve
Old Nov 2, 2003 | 09:13 AM
lowrider's Avatar
No the gasket is a regular gasket, the black gasket (don't know what else to call it) that fits between the top plenum base and the top (the part you replace) like the bologna between two slices of bread.
Lou
Old Nov 2, 2003 | 11:00 AM
vgrani1g35's Avatar
hey gnome, is your car auto or stick. why did u only run a 14.3 with all those mods. i ran a 14.0 with an intake and exhaust, and should have been in the 13s if i got my launch down. something up with your time.
Old Nov 2, 2003 | 12:12 PM
bullseye's Avatar
The time differences probably have a lot to do with where you raced. If one raced at relatively high altitude/high temps and the other raced closer to sea-level at lower temps, you may have quite a significant difference on time, speed, etc....
'03 G35 5AT Sedan, Garnet Fire/Willow
18x8 SSR GT1/Bridgestone S03/Eibach
Old Nov 2, 2003 | 12:51 PM
G35Gnome's Avatar
Mine is an auto and my problem was the tire spin at launch , look at my 60ft 2.347seconds thats pretty bad. Yes I should be in 14 flat, we will see next year for sure when i get better much wider tires.
Old Nov 3, 2003 | 10:04 PM
G35Girlie's Avatar
Yeah you should be in the 13's with that speed. You gotta figure a way to stop all the wheel spin. Glad to hear your gettin better with the launches.
2003 Brilliant Silver 6MT
Injen Intake
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
TNRocker
Sep 21, 2015 08:36 AM
DRG35R
Sep 16, 2015 05:33 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
