Blitz intake filter
Blitz intake filter
As we speak, SP engineering are shipping my Blitz Intake to me ;-) Should be here in 2-3 days. Man, I had to wait a long time for it to get here, it had to be ordered from Japan, but I'm stoked ..... I'll let you all know the process of installation and how the performance increases after I've put it on.
Later,
Colin
G35 Sedan - Desert platinum - willow, winter, premium package and spoiler.
Later,
Colin
Guest
Posts: n/a
Re: Blitz intake filter
ooo....please keep us informed...i'd like to know what it looks like..and piping diameter....also is this intake meant for the jdm v35? cuz last i remember they only have 2.5liter and 3.0liter v35s..whereas we have 3.5liters..which could mean the piping for the intake could be smaller...dunno..maybe
i know the 3.5GT is due out there...but im not sure if it came out already...
95' maxima
95' hybrid accord
WANT 03' G35
95' maxima
95' hybrid accord
WANT 03' G35
Guest
Posts: n/a
The blitz intake is only an adapter and filter. It does not replace the whole pipe from the throttle body to MAF. There was a dyno on FA it made about 10hp and 17TQ if I can remember, but these gains where not through out the powerband in some RPMs it lost power.
When adding on the air filter only, there will be torque gains throughout the rpm range, infact the torque is available at much lower RPM which should reduce some of the takeoff lag that is being experienced . Only when adding a muffler will there be torque losses.
Colin
Colin
Well, it's on and sounds fantastic, installation took about 45 minutes (couldn't figure out how to remove the old filter box ;-()
Took it for a little drive, torque is definately improved from 3k up, and the sound as we soar towards the red line is simply breath taking ...
Have a look at the installation process on my rides page ..
<a href="https://g35driver.com/rides/detailride.php?cat=&relIdx=12&vehId=62">My Ride Page!!</a>
$260, it is a special order from Japan, and the installation instructions are all in Japanese (luckily my wife is from Japan).
Colin
Colin
Looks nice, but looks like a custom job is do-able as well. Probably won't get the performance numbers though. Did you disconnect the battery then re-connect it, so that the ECU resets and knows you have a performance mod? This eliminates the chance of seeing the Engine light on if it detects errors.
No I did not, should I do this, I've heard of possible problems with the engine disabling itself because of security measures. Hmm, I'll have a look at this tomorrow maybe.
Colin
Colin
Well, it was recommended on some Honda forums and my previous J-Body (Cavalier/Sunfire) forum. This is a far better car so I don't know what will happen, but then again it's just disconnecting the battery so there shouldn't be any problems. When you re-connect the battery, start your car and leave it on idle for about 5mins so that the ECU fully re-programs. Ask a real mechanic for more info/advice before you do it just in case.
Ok, will do. Although I don't really want to phone up infiniti service for advice as they'll probably bitch about me adding aftermarket parts :-) .
Colin
Colin
