k & N filter question
Old Feb 8, 2007 | 11:45 PM
chinaman_87's Avatar
does the K & N filter come standard with the 03 g35 sedans? thanks
Old Feb 9, 2007 | 12:20 AM
SFG356MT's Avatar
No.
Old Feb 9, 2007 | 07:09 AM
cato's Avatar
SouthernComfort Moderator
The 03 and all others I believe come with the Nissan paper filter......
Old Feb 9, 2007 | 09:26 AM
fortified's Avatar
Amsoil makes a low restriction panel filter, easy to clean, using nano-fibers. No oil to mess with. P/N is EAA74. Good for 50K miles I think.
Old Feb 9, 2007 | 11:18 AM
Q45tech's Avatar
Iron flat the oem filter and measure the total square area [pleat depth and number of pleats].
How can a filter last longer than oem. Dirt has weight see which one weighs the most..........works the best at collecting weight.
Your piston rings and bearings will thank you.
Order half a case 6 oem at discount from Inet based discount dealers.
Old Feb 9, 2007 | 12:07 PM
thanks i guess the previous owner bought one.
Old Mar 27, 2007 | 09:57 AM
fortified's Avatar
How can a filter last longer than oem. .
That's easy, Amsoil appears to have the same surface area, plus superior material.
Old Mar 27, 2007 | 11:27 AM
gary c's Avatar
Filtering questions............
No, but you can find them at most autoparts stores. Retail is between $30
and $40 and just drops in like the OEM. All you need to do after that is clean
it every 5K miles with the K&N kit....$10.95 most stores!
Old Mar 27, 2007 | 09:35 PM
fortified's Avatar
Every 5K????? Don't think so..it's more like every 30-50K. Maybe you meant 50K.
Still, very thin cross-section and uses oil.
The AEM poly fiber are Amsoil nanofiber are a much better solution IMO.
RA081024
Sep 7, 2015 01:29 AM
CrazyLogic219
Aug 13, 2015 06:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
ClwMike
Jul 23, 2015 12:55 PM
