MAF Housing Broke! Please Help!
Help PLEASE!!! I am a total idiot, I am in need of a MAF Housing for a G35 coupe, although I am sure they are the same for both the coupe and sedan.
I was installing a Pop Charger and accidently cracked the bottom two bolt brackets on the housing.
So to anyone out there who has installed a CAI and has this piece laying around please help me out! Infinity / Nissan says that I can only buy it with the MAF which means they want my first born child
Here is a picture of the installation withe the piece circled in RED.
[IMG]
[/IMG]
please PM, or post as I will be checking this often. Thank you!
[IMG]
[/IMG]please PM, or post as I will be checking this often. Thank you!
That looks like the Stillen HiFlow AirBox, not the PopCharger. The MAF is going to cost you around $900.
This really hurts.....
Sorry to hear of your misfortune.
The picture is just an example to show the part that I broke. It is a good picture that I hijacked from somewhere else. As far as the MAF, it is ok, I only need the HOUSING. But the dealership only sells it as a together. Which means it is a $550 part
Get a different intake tube that goes all the way from the throttle body to the Stillen air box. It will have a spot to mount the MAF and it'll look a lot better than your carbon fiber tube attached to the stock MAF housing. There are several available at reasonable prices. Let me know if you want to see mine (polished stainless) and I'll post a picture. (And to those that will say that any kind of metal intake will produce hot air going into the engine, it's hogwash. The air travels too fast to heat up. I've never even experienced a rough idle in 100+ degree Texas days)
This is what I have and I love it: http://www.grubbsperformance.com/Mer...G35CoupeIntake
Originally Posted by DaveB
Well it's not hogwash because at slower speeds and at a stop, the intake air temp will skyrocket. The higher intake temp will retard timing and richen the fuel mixture therefore reducing power. You won't notice any change in idle though. The ECU is very quick to compensate for conditions. If metal intake pipes didn't make a difference, you'd see expensive cars like Ferrari's and Lambos using metal intake pipes.
Skyrocket?? Have you actually measured the intake temperature? Even if it is a bit warmer, like you said, the ECU is very quick to compensate for conditions, thus, not really a problem. (I doubt if most of us sit at stop lights worrying whether we're putting out 287HP or 286HP because the intake temperature has gone up). I would be willing to bet that the difference is no more than what is experienced on a hot day versus a cold day...
