Z tube thought
Old Dec 4, 2003 | 09:56 PM
speedeezx's Avatar
Z tube thought
So I'm installing Gords grounding kit ( I'll give some input tomorrow) and the Z tube. I pull out the stock intake and think as I'm looking at it.......
" why did I buy a Z tube when I could have pulled this resonator off, plugged the hole it left, then reinstalled it as essentially the same piece ?"
Am I the only one that had this thought?!
Of course, if anything, I'm completely diggin' the new sound !
Old Dec 4, 2003 | 10:22 PM
tbusguru's Avatar
Re: Z tube thought
You are not the only one,I thought almost the same thing with a twist .
Plug both holes and put back just the cap of the resonator for asthetic purposes, to fill the gap left by it when the Z tube is used.
You are so right, other than the holes they are identical, and to me the "G" tube seems to be made with better care, it seems of higher quality materials .
Old Dec 5, 2003 | 01:49 AM
DaveO's Avatar
Re: Z tube thought
I recommend you do a precise comparsion between the stock G35 Air Duct and the 350Z Air Duct while you have them both in hand. I found quite a bit of difference when I did it. It helps explain why there was a documented 5.7 hp & 4.2 ft/lbs torque gain on a Coupe.
Old Dec 5, 2003 | 01:58 AM
xkoraznboix's Avatar
20 Year Member
Re: Z tube thought
the Z duct has bigger diameter than G35's tube... bigger = more air flow...
i think...
Old Dec 5, 2003 | 03:03 AM
badtz's Avatar
Re: Z tube thought
and you wouldn't want those plugs coming out under vacuum and going into your cylinders....pretty high risk for saving money on a part that costs only $70.
Old Dec 5, 2003 | 06:59 AM
speedeezx's Avatar
Re: Z tube thought
Any hp differences were based on a stock to stock comparison. I'm going to bet that a modified G tube has never been dyno'd. Perhaps the hp difference wouldn't exist ? I realize this would require some extra work and access to a dyno at your leisure but it would be interesting just for curiosity's sake. I definetely agree with the plug coming free into the intake comment although a plastic resin should work. Either way I'm leaving the Z tube in, I'm just throwing out some thoughts.
Old Dec 5, 2003 | 11:53 AM
G35MadMan's Avatar
Re: Z tube thought
Also a torque loss down low, perhaps explained by that larger diameter.
2004 Black 6MT
Old Dec 5, 2003 | 03:58 PM
cliverman's Avatar
Re: Z tube thought
Old Dec 6, 2003 | 03:22 AM
nuttyprof's Avatar
Re: Z tube thought
what if you just duct take the holes? would that work? i dont think the duct tape would get sucked down. hmmm. i think im gonna do this then. might be a good money saver.
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
Old Dec 6, 2003 | 06:38 PM
badtz's Avatar
Re: Z tube thought
how are you going to get to the holes? put the tape down the main duct? that would mean that your taping the inside of the duct and that may not hold up to the negative pressure over time.
Old Dec 7, 2003 | 12:55 AM
RamboRami's Avatar
G35driver.com Moderator
Re: Z tube thought
yeah duct tape will not hold, the best way would be to cut off the resonator and perhaps "weld" the opening with another piece of plastic. Now i said "weld" with quotes because it is plastic so the welding or melting process is a little different than your typical gas/arc welding of metals.
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake
Old Dec 7, 2003 | 03:48 AM
badtz's Avatar
Re: Z tube thought
i would think that it's not worth the effort (or the risk). just cough up the 30 to 70 bucks.
Old Dec 7, 2003 | 05:39 AM
Fireball's Avatar
Re: Z tube thought
If you're concerned with keeping the intake tube looking stock, why not remove the top resonator chamber from the stock tube and glue it to the Z tube?
<font color=red>2003.5 Garnet Fire/Graphite G35 6MT Sedan</font color=red>
Premium Package • Navigation • Winter Package • Aero Package • 350Z intake duct • Stillen high-flow airbox
Old Dec 7, 2003 | 05:46 PM
nuttyprof's Avatar
Re: Z tube thought
i mean to chop off the resonator, then tape around the whole tube. yea sure it'll look ghetto, but honestly, i dont care. think that'll work ok? or maybe just get a piece of plastic and take that onto the tube.
wuzz-upp
Oct 3, 2015 04:21 PM
yosip1115
Sep 9, 2015 03:30 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
