got my ztube/popcharger. Question.
Old Mar 19, 2007 | 05:52 PM
888's Avatar
888
I read the DIY instructions on how to install the popcharger.
Just curious, unlike the CAI there is no chance of the car to stop running out of nowhere correct?
And, has anyone had complcations with the popcharger?
I'm about to install it, hopefully it will be easy, i'm not much of a mecahnic whatsoever.. lol.
For those of you who've installed it themselves, was it an easy process, and how long did it take? Is there anyway to know if it's installed properly or not?
I also read that the AC wire, needs to be covered, does anyone have a picture a close up of what needs to be covered, and what is the best material I should use to cover it with?
One last question regarding the ztube i've read some people had fitment issues, like rubbing ect ect.. should i be concerned if mine rubs against anything else?
Thanks.
Old Mar 19, 2007 | 06:35 PM
DrewTheSuit's Avatar
check the intake/exhaust forum for a sticky on this, but i believe you can adjust/rotate the z tube to avoid rubbing the a/c line and won't have to cover it.
Old Mar 19, 2007 | 06:40 PM
ndlive's Avatar
popcharger/z-tube install diy :
http://www.imagestation.com/album/pi...?id=4287496321
Old Mar 19, 2007 | 06:47 PM
Hi-TechG35's Avatar
ZZ-tube and pop charger should take you no more than a half hour to install. Just make sure to disconnect your battery when installing so that way you can "re-train" your ECU. I haven't had any issues here with mine. Just make sure you keep your filter clean otherwise your MPG's are going to suck.
Old Mar 20, 2007 | 02:18 AM
888's Avatar
888
Do i have to disconnect if mine is an 06, i heard the ecu's are different.
Old Mar 20, 2007 | 02:20 AM
abcquackyxyz's Avatar
you dont have to reset the ecu. the ecu will learn in time..just dont have the keys in the ignition if you unplug the maf sensor...
Old Mar 20, 2007 | 02:22 AM
888's Avatar
888
Originally Posted by ndlive
thanks very useful.
Old Mar 20, 2007 | 11:22 AM
chinaman_87's Avatar
^ great link. only took me 45 mins.
AT23
Sep 15, 2015 07:44 PM
Terry_G35
Sep 10, 2015 08:17 PM
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
