View Poll Results: Nismo y-pipe or Stock Y-pipe for my setup?
Nismo Y-Pipe
24
85.71%
Stock Y-pipe
14.29%
Voters: 28. You may not vote on this poll
OEM or Nismo Y-pipe w/ Nismo Headers,spacer, mrev2, and oem exhaust?
Old Mar 25, 2007 | 11:13 PM
jonnylaw's Avatar
Ok-So basically my setup consists of nismo headers, mrev2, 5/16 spacer. As of now, I do not plan on getting a full exhaust system, but I have recently acquired a nismo y-pipe.
I know that there is a bottleneck issue of airflow if I use the nismo w/ the stock mid-pipe back, b/c the connection to the midpipe is 3 in. instead of 2.5. But, given this, would it still be beneficial to have the nismo y-pipe instead of stock for my current setup?
In other words, will the change in airflow w/ the nismo y-pipe completely cancel out any gains it might otherwise achieve (or will there still be some minimal gain).
Since I already have the nismo y-pipe, I want to put it on (Even if only minimal gains), but not if it will result in a performance decrease or adverse effects.
What do you all think?
Old Mar 26, 2007 | 12:12 AM
diablo1356's Avatar
search. its been discussed many times. ypipes generally do nothing, and tend to hamper performance.
Old Mar 26, 2007 | 12:28 AM
jonnylaw's Avatar
^^I did search, but did not find a definite answer on whether installing an aftermarket y-pipe w/ stock from the y-pipe back will result in WORSE performance than the stock y-pipe. Does "tend to hamper performance" means worse performance installed than not installed, or minimim gains/no difference?
Old Mar 26, 2007 | 11:43 AM
GT-Ron's Avatar
The consensus seems to be that when running headers & cats an aftermarket Y-pipe will cause a significant loss in low-RPM TQ. After my headers/cats, I'm a little more inclined to believe it. Of course, I'm sure there are those running headers, cats, Y-pipe and aftermarket rear-section that might not agree.
But if you'd like to try, I still have my *new* NISMO Y-pipe that I never installed. At this point, I'd be willing to work a real good deal for anyone interested in it.
FWIW, I would have installed it if I hadn't changed to the Crawford cats.
Old Mar 29, 2007 | 01:39 AM
jonnylaw's Avatar
bumpy bump
Old Mar 29, 2007 | 12:08 PM
GT-Ron's Avatar
Sorry man, just read it again.
You can get a reducer cone to taper the transition. Dr. Gas was where I got the one I was going to use with the Y-pipe. It's about 6 inches long, so the transition is smooth. He made a big run a long while back, but he might have some remaining. Otherwise, a muffler shop can get something together for you.
mjfenix
Aug 17, 2017 05:49 AM
IEMaestro
2nd Gen (V36) Sedan
Oct 22, 2015 09:09 AM
Frostbite91
Aug 12, 2015 05:16 PM
yoyoyo8
Aug 12, 2015 03:04 AM
