insulated z-tube
Old Dec 23, 2003 | 07:50 PM
ruffrider's Avatar
insulated z-tube
i've noticed in some pictures where people have insulated their intake tube. would this help at all? i just ordered a z-tube and a stillen air box and was contemplating on whether i should insulate mine before i put it in...
Old Dec 23, 2003 | 08:09 PM
Msedanman's Avatar
O.F. Administrator
Re: insulated z-tube
Yes it helps insulate heat from the cool intake air. It's only a little thing but every bit helps. The cooler the intake air > the denser the air > hense more power.
<font color=red>G</font color=red>S<font color=green>M</font color=green>
<font color=red>G</font color=red>S<font color=green>M</font color=green> <font color=black>Silverstone Coupe</font color=black>
Old Dec 23, 2003 | 08:19 PM
DaveO's Avatar
ruffrider,
Cooler air = more power. Decided to insulate my Z air duct after identifying the temperature on the underside near the throttle body was 190F. Gsedanman and socalted have also done so. Ted's lace-on insulation should be easier to install than the wrap-on I used. I believe the insulation helps, especially when you live in the middle of the desert like me.
DaveO
2003 G35 Sedan - DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TechnoSquare ECU
Street Edge TC / Stillen Exhaust System
Old Dec 24, 2003 | 12:30 AM
AirSplat's Avatar
So basically, it's suposed shield out the heat. But some people debate the benefit of this as most people think tha by the time it reaches the plenum, the air will heat up really quickly passing right above the engine. So, the benefits are debatable, but to each his own! :-)
You should try it and let us know if you think there is a difference. :-)
'04 G35 6MT Ivory Pearl
K&N Drop In / Stillen Grounding Kit
Borla Headers/Dual Cat-Back Exhaust
Nismo Front Bumper/Side Skirts
Impul Rear Bumper/Spoiler
AirSplat.com for AirSoft Guns!
Old Dec 24, 2003 | 09:31 AM
Daniel_G's Avatar
has anyone verified this using autotap or similar scanning tool? I know with autotap you can view live data including Inlet air temperature...and log it. (http://www.autotap.com/autotap_for_windows.html#). Either way it couldn't hurt to insulate it, but I'd like to run autotap on a car with insulation, and one without...just to see the results
Old Dec 24, 2003 | 07:48 PM
DaveO's Avatar
Daniel_G,
Isn't the inlet air temperature measured with the air flow at the Mass Air Flow Sensor? Wouldn't the temperature sensor need to be at the throttle body to measure the actual temperature of the air delivered to the engine?
DaveO
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
