Just installed the Z-tube/pop charger..But..
Old May 5, 2007 | 08:48 PM
edindaclub's Avatar
just installed it..but i dont feel much differneces, the only differences is my RPM goes faster than it used to be..
Old May 5, 2007 | 09:02 PM
MeetJoeAsian's Avatar
what kinda feeling were you expecting? the horsepower gain is not noticeable...
Old May 5, 2007 | 09:04 PM
Potty_Pants's Avatar
at the very least you should reset your ecu.
but the gains on a ztube may only be a few horses and for a 3500 lb car... = nada.
ppp
Old May 5, 2007 | 09:05 PM
yah...unplug your battery for about 12 hours..or search for the steps to reset without taking out the battery
Old May 5, 2007 | 09:08 PM
Concealed StrateG35's Avatar
I installed a Z-tube and only because it was free my friend did not want it any longer and it sounds GREAT when your RPMs are around 4500-5000 sounds deep like aftermarket intake, but as far as the car is faster...ummmm It feels the same to me, the HP gain that you get from it get's lost before it gets the the wheels, so ultimately your WHP will be the same, meaning you won't feel crap
Old May 5, 2007 | 09:30 PM
RPL's Avatar
RPL
12 hours? Doesn't it only take like 20 seconds?
Old May 5, 2007 | 09:58 PM
+1 I thought it took maybe 10-20 seconds tops. and all you have to do is disconnect the battery and you are set, someone correct me if i am wrong on this, maybe i've been doing it the wrong way all this time
Old May 5, 2007 | 11:22 PM
edindaclub's Avatar
Is the Stillen Airbox sounds any better than JWT ?
Old May 5, 2007 | 11:28 PM
edindaclub's Avatar
and what happens if i reset the battery? can i not to since i dont know how?
Old May 5, 2007 | 11:34 PM
Skaterbasist's Avatar
Retired SuperMod
You're NOT suppose to feel any power from an intake.
My car definately felt more responsive, but no power gains what so ever.
If you wanted power, you definately got the wrong mod.
They do sound sweet though; kinda like a mini turbo
Old May 5, 2007 | 11:38 PM
maj83's Avatar
lazy a$$
^+1
I like it when it whistles
Old May 6, 2007 | 01:41 AM
SkyBlueG35's Avatar
^my injen short ram sounds almost exactly like a turbo at 3500-5000RPM
Old May 6, 2007 | 04:18 AM
when you plug the battery back in, expect your throttle and engine to rev kinda akward cuz your ecu is reconfiguring itself...if you don't feel that, then your ecu is not reset...it takes at least 12 hours for it to clear....OR...you can search for the method to do it without unplugging....you don't need to reset, your ecu will learn over time...but if you want to reset ASAP, then I suggest you either unplug or follow the steps....
search the string "ecu reset"
Old May 6, 2007 | 06:50 PM
WaLLy's Avatar
Ed, I told you about that combo not having any power increase and it was only gonna be in your head
an intake won't give you noticeable increase unless you go to the track befoer & after the mod. So yea, start going to the track
