Question about K & N Air Filters...
Re: Question about K & N Air Filters...
From what I've read, they both fit. I personally have #332031-2
because that's what is listed for 2003. But apparantly #332259 also fits. That particular p/n is for 2004.
Follow the instructions tho, because one of them, I've forgotten which one, needs you to have some foam spacers(supplied) to make the filter fit properly.
<font color=red>G</font color=red>S<font color=green>M</font color=green>
<font color=red>G</font color=red>S<font color=green>M</font color=green> <font color=black>Silverstone Coupe</font color=black>
(33-2259) is the number they listed in k&n website for g35,which i never see.i got mine at autozone for $44.99 and it's (33-2031-2). it fits and works perfect...
GSM,
I also have # 332031-2. It came with extra "stuff" you mentioned. I didn't use anything but the filter as it fit and sealed very well by itself.
DaveO
2003 G35 Sedan - DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TechnoSquare ECU
Street Edge TC / B&M Cooler / Stillen Exhaust
DaveO
DaveO, I believe the 33-2259 filter is slightly larger than the 33-2031-2, and doesn't need the foam spacers. Having said that, and after checking my install, I found that I didn't use the spacers either.
Maybe the original filter (with the spacers) also has another application that we're not aware of.
I'm not positive, but I thought I remember something about the 33-2031-2 also fitting the Max or something, which needed the spacers.
<font color=green>GroundingGear™ Equipped </font color=green>
GSM, GordGee,
I got my # 33-2031-2 well before it was listed for the G35 Sedan. (The coupe was yet to come.) I believe the extra "stuff" is used for the Altima and/or Maxima application.
Way back when, I believe someone compared the two filters and found a small difference in thickness. The bottom line is they both will fit the G35 Sedan and Coupe without a problem.
DaveO
DaveO
Yeah, I put mine in Mar/03. Maybe that's where I heard that it was the Max app. When did it list for the G? Just shortly before that if I remember correctly (or not, old brain cells[img]/w3timages/icons/laugh.gif[/img])
FS[Texas]: KSport Air Suspension G35/350Z/M35
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
