Safe to add mrev2 and spacr to 05 rev up motor?
Old May 11, 2007 | 01:55 AM
Boostwhore's Avatar
IM curious if its safe to add the mrev2 and 5/16 spacer to the 05 rev up motor.... along with and exhaust and intake... I just dont understand why it would be safe on a 05 and not on a 03-04 does it recalibrate itself on the 05s for the added air? thanks
Old May 11, 2007 | 01:59 AM
Concealed StrateG35's Avatar
03-04 non-revup motor (regardless of tranny)
AT = non rev-up motor (regardless of year)
MT 05-07= revup motor
Mrev2 and a spacer on the non-revup engines have shown issues with running lean
On other hand
Mrev2 and Spacer is a GREAT combo for REV-UP engines
Old May 11, 2007 | 11:21 AM
rgrmatt69's Avatar
On other hand
So putting just a MD 5/16" spacer in an 06 AT could pose some risks?
Old May 11, 2007 | 11:37 AM
dofu's Avatar
20 Year Member
MREVs are for the rev-up motors... the only difference is that the MREV2 is slightly more machined than the MREV. The MREV will add about 15 lbs of torque while the MREV2 also adds 1 or 2 hp
Old May 11, 2007 | 11:38 AM
izmir41500's Avatar
G35driver Addict
i have an 05 6MT with z-tube, mrev2, and 5/16 spacer. it shouldn't pose any problems. i plan on gettin an exhaust in the future.
Old May 11, 2007 | 12:11 PM
b00stedjustin's Avatar
there's a difference between the mrev2 and just the spacer. Plus the mrev2 as listed above is fine for any AT G. You should be fine if you put the spacer on.
Old May 11, 2007 | 12:12 PM
redlude97's Avatar
Adding mrev2 and spacer is okay for the revup motor, for a nonrevup motor, use one or the other, not both unless you have a way of tuning your a/f, as it has shown to get lean with both on a nonrevup motor.
Old May 11, 2007 | 12:17 PM
Boostwhore's Avatar
does anyone know why this doesnt cause an issue with a rev up motor, has anyone logged the air fuels to make sure there safe?
Old May 11, 2007 | 12:27 PM
RebelinRI's Avatar
Thr Rev-up motor has a better EM (engine management) the previous years. It can adjust more readily than the EM's from earlier years to your mods.
BTW I have an 06MT and dyno before and after this mod. It showed a lean condition for me, but it was because I missed a hose. DOH But all is fine now.
Old May 11, 2007 | 02:20 PM
mxkon's Avatar
So here is another question, I have an 03 (obviously non-revup motor) and as a future mod I am considering, Mrev2 + 5/16th spacer + upgraded fuel pump + turboXS engine managment. In my thinking this would help add a nice bit of power and also compensate for any problems usually attributed to running lean on the earlier engines. Is my thinking correct or will this mod likely lead to engine problems for me down the road?
Old May 11, 2007 | 02:54 PM
Beebo's Avatar
Mrev2 and 1/2 Spacer is a good for REV-UP engines with an exhaust because you lose some low end tq and the 1/2 spacer helps
Old May 11, 2007 | 03:21 PM
mike281's Avatar
Mike Team350GZ
5/16 ftw
Old May 11, 2007 | 03:22 PM
ttrank's Avatar
Grocery getter
The spacer is a great mod and the MREV is a nice add-on for the rev-up guys.
Old May 11, 2007 | 03:27 PM
BadBoy06's Avatar
and the MREV-2 with 5/16 gives you back HP up top.
Forgot my dyno #'s but with current set-up (including exhaust with HFC's)
I gained over 20ftlbs tq & over 25 HP through out power band.
Old May 11, 2007 | 03:28 PM
gary c's Avatar
Ask the "right" person.............!
Why not go to the mfg and ask them this question? MotorDyne.....Tony
661-993-5111.......Rather than getting opinions you'll get the correct answer!
Damn, I hate being right all the time.........
