installed stillen intake now car won't start properly
Originally Posted by keemowerks
in the mornings the intial startup is fine. after that is when i get problems starting up. i start the car and it "spudders and dies", unless i give it a little gas.
there is a whistling sound but from what i read thats the intake. could it be a air leak then? i made sure everything was tight.
-GP-
ok, i had gdup35sedan check out my problem. lucky for me he was down the street from my work. he took the intake out and reinstalled it, disconnected the battery and started the car. but just like before the car spuddered and died. gdup then checked out the battery and said it could be the battery.
so again guru's: any thoughts? second opinions?
if this doesn't work, i'm putting the stock intake back on.
thanks to gdup35sedan for the help and all the others with the advice.
I hope you get this figured out... Like gdup35sedan said, try a new battery. If that doesn't work, put the stock intake back in. If that still doesn't work, leave the stock intake in there and take it to the dealer - there's one in Kearney Mesa and another in Escondido. You should be covered under warranty.
Norb
kenthung
07-21-2015 05:56 AM
