I just installed a Z tube and replaced to an Amsoil drop-in....
A buddy at work gave me his Z tube for free so I dropped that in along with a new Amsoil filter....and I can feel the difference in the throttle response in the car. Maybe it's cuz the old air filter hadn't been changed in 2 years and then I dropping a Z tube in there REALLY made a difference then. I heard everyone saying be careful and make sure you don't rub the A/C line when installing the Z tube, but there's no way possible to touch the A/C line...is it because it's an 05? or did I miss something?
My other question is whether the resonator or that pipe in the airbox should be plugged? any conclusion to the purpose of that? I've read many responses and VIEWS, don't know which way is right...
Originally Posted by g35rcr
that could be it...you should change a paper filter every 2 oil changes...and the a/c line rubbing is with the jwt poop charger and their **** poor bracket
thank you...
which resonator are you talking about...the one on the stock intake line? that is a part of the stock setup to reduce noise
Originally Posted by MeetJoeAsian
nope...the one INSIDE the airbox where the filter goes...
