HELP...OPINIONS...FI intimidator exhaust installed
Old Jun 8, 2007 | 01:26 PM
05BLACK6MT's Avatar
To my knowledge
Header + HFC/TP + any exhaust = drone/loud
When any exhaust design they did it with stock setup in mind, and when you added stuff to it. it will sound different. It may sound good to some but not to other...
Old Jun 8, 2007 | 02:11 PM
SuperShick's Avatar
anyone else with the same combo, Cats + Headers + FI Intimidator Exhaust have the same problems? Even FI Intimidator + HFCs....let's see a show of hands and who's having problems.
Old Jun 8, 2007 | 02:32 PM
speedgeek's Avatar
i drove around for 2 months with just the headers and metallic HFC with the stock exhaust..other than rasp it was fine
Old Jun 8, 2007 | 02:34 PM
Calvin's Avatar
Overglorified Altima
fi ceramic cats + fi exhaust sound amazing by themselves.
Old Jun 8, 2007 | 02:38 PM
SuperShick's Avatar
that's exactly what i have and it's really, really loud. louder than i expected
Old Jun 8, 2007 | 05:00 PM
rcdash's Avatar
FI metal cats + FI exhaust was louder than I expected also, but not too loud (my car is well padded with dynamat though). Just deeper and meaner. I do get drone around 1800 rpms but I usually just rev about that in MM mode (5AT here). The sound at high rpm is much more exhilirating than I anticipated.
I've got some turbos going on so we'll see how well this thing sounds and flows with twins... (they should help silence the exhaust tone)
Old Jun 8, 2007 | 11:05 PM
G05C's Avatar
I have the Intimidator and an AT. Since the beginning I have talked to Tony about the drone inside the cabin. It was intolerable in the beginning but now, I'm a little more used to it. My friends complain about the noise inside my car all the time....
I was contemplating getting the HFC but I am really worried that it will just increase the drone inside my cabin.
Currently, I only have the exhaust - no headers and no cats.
Tony was more than willing to help me out but, as Rick says, AT's usually have this drone with aftermarket exhausts.
Old Jun 9, 2007 | 01:30 AM
SuperShick's Avatar
dude, if you get HFCs, you're gonna get even more drone.
i've got 6MT, FI Intimidator + FI HFCs and there's A LOT of noise in the cabin
Old Jun 9, 2007 | 04:39 AM
G05C's Avatar
Thanks for the info....saves me 5 bills
Old Jun 9, 2007 | 11:15 AM
ISMSOLUTIONS's Avatar
correct, if you already have drone you don't like, don't further free up the exhaust, you can get even more.
Also, all, give Tony a call...see what he says.
Rick
Old Jun 9, 2007 | 07:10 PM
speedgeek's Avatar
Update:
This morning I wanted to test something. I made two copper exhaust gaskets; I made the pipe hole a little smaller than the gasket size and placed them after the cats. This of course chokes the flow a bit. I started the car and it was quiet, I mean quiet. Sounded stock. The LOW rumble was there but it sounds stock. Drove around and the car drives great, side roads and parkways.
OK...so...here we go…
Clearly this copper gasket is negating all the modifications I have done to the exhaust, but I just wanted to test if the car would run ok with a slightly reduced exhaust flow and it does.
I love the low rumble of this FI exhaust; I love the build, the look, the quality. Everything but the 24 x7 day a week LOUD rumble when I drive.
I will want this loud rumble sometimes. Sometimes I will want my car to sound like it will eat small animals and anything else in its path. At the same time, on my daily commute of 30 miles, I don’t want the drone, and tooth filling removing rattle.
My solution:
Instead of ripping out the exhaust & selling it, installed whatever else…etc. ($$) I’m going to purchase 2 electronically controlled exhaust gates off eBay. They seem very well made and the folks on the Supra and Mustang forums love them. I wasn’t expecting to spend any more money, but I’d rather keep my setup and just regulate the exhaust note when I want. I think this solution will work well and I’ll update everyone on the progress. I’m open to all opinions good and bad.
Thanks
Old Jun 10, 2007 | 01:15 AM
rcdash's Avatar
great work. please report back w/ how it turned out, parts, costs, install, etc.
what diameter hole did you make in the gaskets?
thanks.
Old Jun 10, 2007 | 02:48 AM
Sponger's Avatar
6MT Brembo Coupe
Not too familiar with the FI exhaust, but how about an x-pipe and/or resonators?
Old Jun 10, 2007 | 12:16 PM
DaveB's Avatar
I noticed the same drone and vibration with my Borla TD. The rest of the exhaust was completely stock. The drone was obviously caused by the larger piping diameter and higher flowing muffler/resonators, but a majority of the vibration was caused by the lack of flex sections in the y-pipe. Nissan puts flex sections in the stock exhaust for a reason.....to reduce NVH. I know the FI system doesn't use flex sections nor does Borla, Stillen, and most others. I think HKS is the only one that was smart enough to incorporate flex sections into their design. You may want to consider having a shop install some 2.5" flex sections into the y-pipe while you're getting the other work done.
Old Jun 10, 2007 | 02:35 PM
  #30
SuperShick's Avatar
FI Intimidator is already an X-pipe design
