Exhaust Trick...
Old 06-11-2007 | 04:08 PM
Crashtest77's Avatar
I don't know bc I don't have nav, but can't you just shut it off and turn it back on without having to turn off the car. There has to be a button for it.
Old 06-11-2007 | 05:06 PM
darussiandude's Avatar
lol get off his back everyone he was just telling everyone bout his experience..i really doubt he wrote this so that people would just flame him like the olympic torch. I mean, let him be, his question was as to WHY backfiring after turnin off and on the car happens, not "ignore my question and add your smartass remark on how stupid this is." let him decide if it's stupid or not....
r0llinlacs (04-28-2021)
Old 06-11-2007 | 05:26 PM
Pepper's Avatar
Finally someone understood!
Old 06-11-2007 | 07:58 PM
partyman66's Avatar
It definitely is dangerous, because you lose your power steering when you kill the motor and possibly the brake assist... but I can appreciate interesting little "hacks" like that at least being found. I wouldn't suggest people go out and try this little trick though. Backfires are not good for your catalytic converters or 0xygen sensors, and with a stock exhaust are indicative of the car not running properly(probably too rich, which causes problems with converters and 02 sensors in itself). If something unexpected happened while the car was off, you could be in a situation where you wouldn't be in full control of the vehicle... and who knows what other types of potential hidden errors could happen to the system aside from the blatantly obvious backfires.
Old 06-11-2007 | 10:56 PM
MixturePinoy's Avatar
Ok. I don't know what happend. I almost crashed. I turned the key to "off" on drive,After I did that, I lost all power, including brakes and steering. I had to coast the car on the side of the road, but at 30mph and no steering, I almost ran into a car that was behind me. I got the car to stop with the e-brake in the middle of the street, where i had to put the car into "P" pull out the key, and restart the car. If you have a 5AT, don't do this. . . BTW, no backfire after the incident.
Old 06-11-2007 | 11:08 PM
cipriopt's Avatar
rock on
I'm gonna try it thou
automatic:( (05-06-2020)
Old 06-11-2007 | 11:20 PM
diablo1356's Avatar
ive done this before when my tire pressure light kept going off for no reason...dude you have to put it in neutral..then turn the engine off..then turn it on then shift back into Drive...what you did was pretty damn stupid
Old 06-13-2007 | 02:20 AM
Jeff92se's Avatar
Red Card Crew
Sounds like the injectors either are still firing or the ecu goes into start mode when you start the car again. Either way, it sounds like you are running the car rich and the backfire is the exhaust lighting the mix inside the cats. Good way to ruin the cats by running the rich or breaking the honeycomb apart.
Old 07-03-2007 | 12:34 PM
bulldog25's Avatar
Stoopid don't try this at home.
Old 07-03-2007 | 01:00 PM
RPL's Avatar
RPL
^Jesus...
Anyways, I agree, I don't know why all you people are on his back. He did it once, got an unplanned result, and tried it once again to see if the same result would happen.
Old 11-11-2007 | 07:15 PM
blusky's Avatar
i discovered this a few nights ago myself. Im cali catless tho with cell defenders lol. I want to kno what is happening myself. is it rich conditions that is causing the backfire or refire?
Old 11-11-2007 | 07:45 PM
patman530's Avatar
that's what he gets for installing the XO2 exhaust...
Old 11-11-2007 | 08:25 PM
TIAN's Avatar
Hold The Line
Tried it on my 6mt and got nothin
Old 11-11-2007 | 09:36 PM
Scrooge's Avatar
I think you might have got some preigniton or detonation , turn on the car with the cyclinder compress might have done it.
  #30
Old 11-11-2007 | 09:38 PM
O HELLA OEM's Avatar
post of video..lol
Quick Reply: Exhaust Trick...
