HELP! Service Engine Light
Old Jul 25, 2007 | 08:01 PM
Projekt7Tuning's Avatar
JDM All*Star
I was messing around with my intake stock intake piping and filter box, and now my "Service Engine Soon" light is on. I started the car with the Air Flow Sensor unplugged which I believe activated it. I put everything back together, and still get the light. I tried to dis-connect the battery for 60 seconds and re-connect it. That didn't work...please advice?
Old Jul 26, 2007 | 07:28 AM
cato's Avatar
SouthernComfort Moderator
No problem here. Follow the pedal reset method or disconnect the negative battery terminal for 12 hours or so. Or disconnect the negative battery terminal, hold down the brake pedal for awhile. Make sure the MAF is plugged in properly. All should be good to go then.
Old Jul 26, 2007 | 10:04 AM
ISMSOLUTIONS's Avatar
The battery reset methid is the easiest, and it doesn't take 12 hours. The whole process takes about 12 minutes.
remove negative terminal and wait 8-9 minutes - timed
turn key to on position and hold down brake pedal for 30-45 seconds
remove key and put negative terminal back on
start car and all should be well.
Rick
Old Jul 26, 2007 | 10:29 AM
JDM All*Star
All fixed! I actually just disconnected the negative terminal for 3 hours, reconnected it, and VWALLA! No more SEL light! Thanks for all the help guys!
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Ednica87
Sep 5, 2015 02:59 AM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
