Injen CAI makes my Engine Stall
Old Jan 25, 2004 | 09:49 AM
G35spd6's Avatar
I have a 2004 G35Coupe manual and I had a infiniti dealership install a CAI from injen and the dam car stalls when i am haulin *** it stalls out
Old Jan 25, 2004 | 12:23 PM
Gsedan35's Avatar
Re: Injen CAI makes my Engine Stall
Was a ecu reset performed? And how many miles since said reset. In any event, do a reset and give the ecu time to learn and adjust before you do your high speed runs. Also check the wire's off of the MAF and make sure they did not do the install in such a way that the are messed up some how.
I have the part number 1990 on my sedan 6mt, the pre-redesign, I've never had a lick of trouble, been to 145mph twice dumped the clutch and coasted to 80mph, not a flinch from the tach. But I gave the ECU it's time before hand.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Jan 25, 2004 | 02:54 PM
G35spd6's Avatar
how do u reset the ecu
Old Jan 25, 2004 | 02:59 PM
bullseye's Avatar
Check the FAQ's...
'03 G35 5AT Sedan, Garnet Fire/Willow
18x8 SSR GT1/Bridgestone PP S03 225/45/18Y
Eibach Pro-Kit Springs & Anti-Sway Kit
Stillen Cat-Back Dual Exhaust System
Old Jan 25, 2004 | 03:17 PM
G35spd6's Avatar
I RESET THE ECU, BUT DOES THE LIGHT KEEP BLINKIN AFTER UVE DONE ALL THE STEPS? or does it go out ?
Old Jan 25, 2004 | 03:45 PM
Gordgee's Avatar
Administrator
It should go out after you turn off the ignition and re-start. Otherwise, you'll have to do it again.
<font color=green>GroundingGear™ Equipped </font color=green>
Old Jan 26, 2004 | 10:36 AM
CaribeCoupe's Avatar
You should call INJEN and make sure that you got the correct part number. The early 6mt cars were stalling with the intake. It turned out that there was a problem between the autos (which Injen had tested on and manuals which they had not). INJEN had to re-design the intake for the mt's.
Sounds like you got the part for the auto.
Old Jan 27, 2004 | 06:45 PM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
RD 1992 is for MT Cars.....
Death Has Gotta be Easy. Because Life is just so Hard. It'll Leave you Physically, Mentally, & Emotionally Scarred. "50 CENTS"
NismoCPV-35
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
EPG35
Aug 16, 2015 04:52 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
