Removing the JWT pop charger for cleaning?
Old Aug 4, 2007 | 12:13 PM
clinthammer's Avatar
I have like 20000kms on my filter and decided to clean it although its not that dirty.
I had the JWT pop charger and z tube installed at a garage but want to do the removal of the filter and cleaning myself.
Do I just need to remove the bolts and take out the pop charger or do I have to remove the MAF sensor? Do I need to disconnect the negative terminal on the battery as well?
Or is it just a matter of loosening the bracket bolt holding the metal band at the base of the filter? Thanks in advance!
Old Aug 4, 2007 | 12:31 PM
OhMyG...35's Avatar
loosen the band and pull the filter off. Then just hose it down. Let dry and reattach!
Old Aug 4, 2007 | 12:32 PM
thanks man. Ill be using light pressure to clean it from the inside. Then ill use a k&n recharge kit to oil it
Old Aug 4, 2007 | 02:08 PM
fastGkid's Avatar
yes just take it out spray it off and then re-oil it.
Old Aug 4, 2007 | 08:11 PM
TURBOTOM's Avatar
a.k.a kleicoupe
yea the K&N kit comes with cleaner and oil, that is what i used. Make sure you let the filter dry befor oiling it, and after you oil it let it dry again.
Old Aug 4, 2007 | 11:03 PM
i take it i leave the car off without the filter overnight right?
Old Aug 15, 2007 | 03:19 PM
s2k_g35's Avatar
i took my off at 5pm. Spray the cleaner, let the water run down on the filter and let it dry for about 2 hours. 7:30PM spray the oil on and let it dry until the next morning. Install it back on the z tube.
I also clean my MAF sensor at the same time.
Old Aug 15, 2007 | 05:16 PM
O HELLA JDM's Avatar
yup just remove the bolts...if you use the K&N kit it wont be blue anymore itll be red...its just easier to find/use/price of the K&N recharger kit, but yea if you want it blue you have to get the JWT one
Old Aug 15, 2007 | 06:02 PM
spddmn124's Avatar
use oxy clean and soap... its not joke cleans everything!!! good luck
Old Aug 15, 2007 | 06:44 PM
BayAreaRefuGz's Avatar
i fly low
i heard you can soak the cone in CLUB SODA. i have yet to try this on my stillen intake. the carbonation would "scrub" the filter. i would also like to comfirm this method from other members who has tried it without any problems.
Old Aug 15, 2007 | 07:13 PM
lowrider's Avatar
Why The K&N Kit is not that expensive, but you car is. Clean it right and re-oil it right. When you spray the hose do it from the inside out only. Do not over-oil or you'll screw up your MAF. Let it sit overnight.
Lou
Attached Thumbnails Removing the JWT pop charger for cleaning?-jwt-wk-n0.jpg
Old Aug 15, 2007 | 09:47 PM
RebelinRI's Avatar
Hey Lou........... can you clean up a bit? Looks a little messy.
11bEMT
May 27, 2022 03:13 PM
avalino
Aug 6, 2015 01:42 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
