HFC & Emmisions help.
Old Aug 7, 2007 | 11:01 AM
05GCOUPE6MT's Avatar
I have been researching HFC for several days now. Many say HFC will NOT pass emissions. I understand they will not pass the Visual inspection, but most shops seem more concerned with cars passing the exhaust emissions. I do not even think they will take notice to the HFC anyway unless the car fails. Question; Will HFC pass the strict exhaust emissions standards placed in NYS. I would like to hear from people who have HFC & took their cars for inspection.
Old Aug 7, 2007 | 11:22 AM
killerlexus's Avatar
i passed with testpipes. as long as you dont have a check engine light, you be alright.all they do is plug in OBDII ,to your car, to check diagnostics. make sure you use spacers for the O2 sensor to prevent the CEL.
Old Aug 7, 2007 | 11:32 AM
What do you mean [Spacers for the 02 sensor]?.
Old Aug 7, 2007 | 11:40 AM
suicidesam's Avatar
****defected****
search in here
https://g35driver.com/forums/search....archid=3269105
Old Aug 7, 2007 | 11:54 AM
Originally Posted by suicidesam
I looked & did not see anything regarding a 02 sensor spacer.
Old Aug 7, 2007 | 11:56 AM
Calvin's Avatar
Overglorified Altima
Old Aug 7, 2007 | 02:33 PM
Does the Fast Inension HFC come with the Non fowlers built in?.
Old Aug 7, 2007 | 03:45 PM
_jb's Avatar
_jb
Photographer
Non-foulers (spacers?) are normally for test pipes, not HFC's...
Old Aug 7, 2007 | 03:49 PM
ISMSOLUTIONS's Avatar
You wont get a CEL with HFC's...at least with Fast Intentions. I don't know of anyone who has either...one who did, messed up the O2 sensor itself during install.
Also - HFC's and testpipes, are meant for off road use only - not meant to pass smog, etc...even though they can/do in many cases.
Most people keep the old CATS and swap at test time..less fines or issues.
Rick
Old Aug 7, 2007 | 04:02 PM
Calvin's Avatar
should be more careful with the install next time.
luckily he was able to get his o2 sensor replaced under warranty
Old Aug 7, 2007 | 04:18 PM
Skaterbasist's Avatar
Retired SuperMod
Keep your old cats. I would swap them if you were very worried about not passing emmisions or visual tests.
Swapping/installing cats isn't very difficult as long as you have the right tools.
Old Aug 7, 2007 | 04:19 PM
Calvin's Avatar
it's easier if you have a lift.
install for cats is only 40 bucks (for both, total), anyway.
Old Aug 7, 2007 | 04:23 PM
Retired SuperMod
DIY = Fun
$40 for cat install is pretty cheap though.
Old Feb 3, 2009 | 07:18 PM
tiguy99's Avatar
Wonder if it'll pass here in Chicago. This mod won't make my car go around smogging up the environment will it? I don't want to be driving around blowing smoke or breathing gas fumes everywhere
Jcruzg35
Sep 26, 2015 04:47 PM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
DRG35R
Sep 16, 2015 05:33 AM
FRUG35
Sep 11, 2015 03:07 PM
