Urgent!! Stud Removal On Plenum Spacer
Old Sep 2, 2007 | 04:55 PM
adusg35's Avatar
My friend is in the process of installing my plenum spacer and is wondering how to remove the 2 studs that you have to replace with the extended ones! There is one on the left and right side of the intake manifold!
Thankls
Adnan
Old Sep 2, 2007 | 06:17 PM
LMG_35C's Avatar
Small socket (can't remeber size...like 5mm) or screw two nuts onto the studs and lock them together so that you could unscrew the stud with the lower nut. You shouldn't need too much force. It's all in aluminum so be sure the plenum is cold and that you don't use too much force on any of the bolts - torque wrench saves to day. Good luck.
Old Sep 2, 2007 | 06:49 PM
adusg35's Avatar
thanks that helped. we got them out!
Danielek
May 1, 2022 01:28 PM
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
philthethrilloh
Sep 9, 2015 01:25 AM
