invidia g200 carb lega?
Old Sep 14, 2007 | 06:36 AM
Gfast's Avatar
hey, i was been searching around for the answer but not much info come out. i wonder if u guys can tell me if the invidia G200 exhaust is carb legal?
thanks in advance.
Old Sep 14, 2007 | 08:19 PM
Beebo's Avatar
yes but i think if adding test pipes or high flow cats it wont be
Old Sep 15, 2007 | 01:41 AM
Gfast's Avatar
thanks
how about header?
do u think that will affect?
Old Sep 15, 2007 | 04:00 AM
Beebo's Avatar
ISMSOLUTIONS
OK - so further on this:
CARB legal or certification is a bunch of bogus junk for a catback. If your getting headers or CATS - you'd want either Carb certification or OBDII certified CATS - if you intend on passing smog tests.
There are a few sets of headers that are CARB certed and will pass in all 50 states...such as DC Sport, among others. Many CATS are also smog legal, depending on your state's requirements...some only require that you have them and that your car passes the sniff test.
And as SKATERBASIST stated - the real thing to look out for is volume. Too loud, and the cops will get you anyway - then you'll have to make it quieter, swap out for something else, etc. You also want to watch out for the smell - testpipes will pass all of the noxious gases through the tailpipes, cops and others can easily smell it - and they will pull you over and site you, if you have laws that are that strict.
So - to sum up - catbacks are fine, smog-wise - just watch for volume levels when combined with headers, cats etc. Testpipes, likely not and they will give themselves away from the smell. HFC's will not stink and give you the performance edge, but are likely illegal smog-wise in MANY states - so don't get caught with them. Headers - get CARB legal ones, if your state requires it.
Also - just for general FYI - when it comes to CATS/testpipes - they are specifically designed for off road use - so I don't condone, or practice for that matter myself the use of them in any other way
Rick
Old Sep 15, 2007 | 04:29 AM
Skaterbasist's Avatar
Retired SuperMod
Technically its not CARB legal nor illegal. You should be fine as long as the db isn't enough to create problems with the cops; not sure how loud the G200 is.
Old Sep 15, 2007 | 05:25 PM
Gfast's Avatar
thanks for the info
Old Sep 17, 2007 | 06:09 AM
Gfast's Avatar
hey, anybody know how loud is the g200?
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
discoswan
Engine - Exhaust
Oct 16, 2015 10:42 AM
04G35NYC
2nd Gen (V36) Sedan
Sep 13, 2015 02:56 PM
Frostydc4
Intake & Exhaust
Nov 9, 2005 04:22 PM
ShadowG35
Intake & Exhaust
Nov 6, 2005 08:50 PM
