Kinetix plenum dyno results
Old Feb 9, 2004 | 11:47 PM
docmassage's Avatar
Here's the thread of the dyno results. I can wait to hear some of your opinions on it.
http://www.my350z.com/forum/showthre...threadid=60378
Old Feb 10, 2004 | 05:18 AM
skeleton_cru's Avatar
Sedan
Re: Kinetix plenum dyno results
If you are not a member you can't view the post. Can you cut and paste it here or something to that effect?
Old Feb 10, 2004 | 09:49 AM
z_with_back_seat's Avatar
So here are a couple of the dyno's that came from The Dyno Shop that I went to this morning.
To keep it short, I got NINE runs today!
three - back to back to back in fifth gear.
three more - back to back to back in fourth gear (dyno guys mistake so he did three more!)
then the last three - back to back to back
all the dynos were done at 10:15 - 10:30 am today. It was probably 60ish degrees.
because I spiffed the guy in the back ($20.00) I only got 5 dynos on the file (but I only paid for four which was $135.00! but he actually did a total of nine. He left out the fourth gear runs (which he said were lower by about 10 pts across the board)
If I have to maybe I can get the others emailed to me but i can make no promises about that.
anyway - here are the numbers...
wait - I need to give a small review of the whole set up...
did a baseline with the folllowing mods -
borla dual, UR pulleys, hybrid injen/pop charger full CAI (which I think helps!) and thats it.
the numbers on that were posted earlier but here they are again.
baselines were 243 and 238 torque run one and
248 and 243 for run two.
so best baseline - 248 rwhp and 243 torque
all_bark has attached this image:
G35C - 6MT, DG, Aero, BSM, Flaps, Stillen Intake, Z tube, Crawford, 6 Wire Grounding Kit, Clear Corners, 2nd Battery (Brake) Cover, Sirius, Momo F16 Evo Shifter, 30% 3M Metailic Tint & more to go
Old Feb 10, 2004 | 09:55 AM
Sorry the chart did not attach the first time
check out the other thread for some additional good info.
https://g35driver.com/forums/showfla...&sb=5&part=all
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
9tray turbo
Sep 29, 2015 10:22 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
