HELP! Mid-pipe bolt size/installation question
Old Jan 7, 2008 | 12:17 PM
MM_G3520's Avatar
Hey guys,
I am going to be changing out my coupe mid-pipe for a 05/06 sedan mid-pipe this week. I want to grind down and punch out the studs on the flanges, and I was wondering what bolts will fit the holes.
Can anyone give a bolt size recommendation? Also, how difficult is it to punch/grind out/c clamp out the studs?
Thanks for the help, I've attached the exhaust video of my coupe mid-pipe; I will make another one for comparison with my 05/06 mid-pipe.
Old Jan 7, 2008 | 04:59 PM
w33ps's Avatar
give me a shout if u plan on selling that 05/06 pipe!!
Old Jan 7, 2008 | 05:15 PM
g35freak86's Avatar
I had to drill out one of the bolts on my muffler when putting the middy on. The bolt snapped when I was un-doing it. I forgot what I used, may a 3\4 bolt with 2 washers and a nut. I forget. Drilling out the welded bolt wasn't too bad. Took a LOT of muscle though. Start with a smaller bit and then get bigger and bigger until it is the size of the bolt that is already welded on there. It worked great and is still working flawlessly
Old Jan 7, 2008 | 05:26 PM
derek@grubbs's Avatar
PREMIUM SPONSOR
Thumbs up
It's 10mmx1.25 standard, should be easy to obtain allmost any where,you'll want approx 30 mm long or so, call if can help,thx!
Derek(866)789-0207
Old Jan 8, 2008 | 01:56 AM
geesteezd's Avatar
^+1 learned by my previous install..
yosip1115
Aug 26, 2015 10:46 AM
wuppiedog
Aug 7, 2015 11:16 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
