A silly question about exhaust
Old Feb 7, 2008 | 11:43 PM
rob40wilson03's Avatar
well yeah i knew it was back pressure.... but why does higher back pressure yield higher low end torque?
Old Feb 8, 2008 | 06:55 AM
BryanPendleton's Avatar
Volume is the key and expeling those exhaust gases is one piece of the puzzle. I like to look at the extremes to understand that delicate balance at play, keeping in mind that the desired power band will drive where the balance falls. Lets say you have a 6" exhaust. Exhaust gas velocities are slow, larger viscous boundary layers at the walls, and a lack of fluid momentum. The low fluid momentum is a big key here, as the lack of fluid momentum does not "syphon" the headers/combustion chamber as effeciently. Now 1" exhaust. At this size the viscous drag of the tubing walls is enough to severely choke the engine. Excellent fluid momentum with astronomical fluid velocities, but not enough to compensate for the viscous drag. So the balance is finding the right fluid momentum and velocity to maximize escape of exhaust gases, but not choke the engine with viscous drag.
Muski_G
Dec 1, 2023 11:11 AM
Shizzmaster2k
Engine - Exhaust
11
Sep 2, 2015 04:09 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
