increase airflow to stock airbox mod.
Old Apr 2, 2004 | 01:13 AM
klg35's Avatar
Re: increase airflow to stock airbox mod.
butt dyno says about 2hp and it's all psycological....if you can feel 2hp, you got a sensitive @ss.....however, for gas milage, it actually got 2-3 mpg more.
04 Black Sedan 6mt / front blinker mod, z tube+k&n panel filter / 18" r/h c2s w/khumos 235/40zr18 / stock airbox mod / s-teins / crank pulley / pre-muffler, what pre-muffler?
[image]url[/image]
Old Apr 3, 2004 | 03:33 AM
skaline's Avatar
Ditto on the gas mileage. I'm getting 2-3 more mpg and it just put on 20's. I did the same mod a while back and I did not plug the hole. Seems to me air would be sucked in thru the hole, grabbing cold air from the same space a CAI would grab it from.
Old Jan 13, 2010 | 08:10 AM
slim17265's Avatar
when you took off the power duct pc you visually saw that you opened up a larger intake area....but.....if you look you will see the hood comes down over that area. In stock form it looks like the only air draw would be from the l/8" crack at the leading edge of hood. I removed mine entirely and it did nothing
Old Jan 14, 2010 | 12:54 PM
sexyrob's Avatar
wait... so you are saying removing two pieces engineered for your cars stock intake box resulted in an improvement in performance? hard to believe, but I'll wait for dyno sheets.
Old Jan 14, 2010 | 04:46 PM
halfass872's Avatar
WOW!! Way to raise a thread from the dead!
Old Jan 14, 2010 | 05:03 PM
sexyrob's Avatar
o dam didn't even see that
Old Jan 14, 2010 | 10:42 PM
BrownDogg's Avatar
Nice work on this. Too bad I dont have a stock intake anymore!
Old Jan 15, 2010 | 12:40 AM
Tollboothwilley's Avatar
WOW. 6 year old thread.
Old Jan 21, 2011 | 05:00 PM
G35SedanGrn's Avatar
I took off my power duct today it sounds real nice, i'm debating on putting it back...maybe in the summer when it gets hot and heatsoak would be an issue.
Old Jan 22, 2011 | 08:40 PM
OCG35's Avatar
almost 7 years - might be a record thread bump
Old Jan 22, 2011 | 08:51 PM
G35 Dream's Avatar
I actually cut the resonator off the bottom of the intake box and fabricated another support bracket to help hold it in place. Left the power duct on though. Makes no sense to take that off. Im gonna take it back out though and patch the hole later. Sounds a little better thats all.
Old Jan 22, 2011 | 09:01 PM
sillyoldtayo's Avatar
I dont feel like this would do anything at all except make the intake louder...i also am really skeptical on seeing 2-3mpg difference by doin this. i dont see how i could get 24mpg instead of 21 by takin off part of the factory intake scoop
Old Jan 24, 2011 | 09:46 PM
juan350gt's Avatar
Sean akak XXSEXXXX modified mines,i bought a Z tube and 350Z air bx since the Z box only has 1 hole,In front of the grill He drilled a Hole on the Fiberglass composite and stuck a tube to the air box and added a square funnel behind the grill and presto i am cold air intake with a stock Z intake n K&N drop inn i feel more Horse power than short ram intake and cold air cause no heat soak. Thnx Sean..
Old Jun 30, 2011 | 06:40 PM
buzzking's Avatar
Can I get more info and pix on the mod that Sean did?
I'd like to try it out.
Thanks
Old Jun 30, 2011 | 08:01 PM
  #30
SxExCx's Avatar
^nope, the details are on lockdown! LOL
PM me if you are interested in a custom install (Socal only)
