Received: Crawford Plenum v5
Old Apr 13, 2004 | 05:03 PM
SoCalTed's Avatar
My v5 showed up yesterday... I had ordered it in powder coated blue. It is a little brighter than I expected, and the powder coating is not as perfect as I would have liked. But then again, Doug only charges $20 for PC'ing, and the shops around here and online run upwards of $60 to $120.
Can hardly wait to fit this thing on...+ I got a couple packs of TechFlex to dress up my engine compartment hoses/harnesses.
Stay tuned for some pix!
Cheers, Ted
'03.5 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
Old Apr 13, 2004 | 05:17 PM
Msedanman's Avatar
O.F. Administrator
Re: Received: Crawford Plenum v5
I'd like to see the pics of your new v5. Not sure how it differs from my original plenum.
Good luck with the install-- If it's anything like the original, it won't be hard at all.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Apr 13, 2004 | 10:00 PM
mstil35's Avatar
Got my V.5 Black powder-coated plenum today. Did ALMOST all the install. Was reinstalling the throttle body and dropped the %^*$ 5mm allen wrench. It disappeared somewhere in the underbody pan. Guess I'll have to buy another 1 tomorrow. Will take me approx. 5 minutes to complete my install. Other than dropping the %^& allen wrench, the install went smooth as silk. I'll post pics when I have it completed.
Old Apr 14, 2004 | 12:39 AM
TCFOOL's Avatar
"There is a Very Fine Line Between "Hobby and Mental Illness"
Old Apr 14, 2004 | 12:15 PM
gspot35's Avatar
Have you been just waiting to use that?
I want pictures too! This is my next upgrade!
Stillen c-b Monday, Injen CAI tonight
03 Sedan~5AT~19" rims~Garnet~aero~premium~sport~Stillen Cat-back
Old Apr 14, 2004 | 05:26 PM
mstil35's Avatar
OK Fellows: Here are 2 pics of my V5 black powdercoated plenum. Will post more when camera battery charges!!!
Old Apr 14, 2004 | 05:29 PM
mstil35's Avatar
More pics to come. I have a 350z engine cover on order that I will try to modify.
Old Apr 14, 2004 | 08:14 PM
lowrider's Avatar
Looks Good
Here's my standard Gray one (in my Diamond Graphite Coupe).
Lou
Old Apr 14, 2004 | 08:46 PM
subrobo's Avatar
if you install the crawford plenum, the engine cover cannot fit? did you sut it yourself?
Man...all i gotta say is that the stock engine cover make it looks really hot...
Old Apr 14, 2004 | 10:17 PM
gte192t's Avatar
I've heard the stock cover will fit, it will just be a little snug. It looks like the guy above your post cut it to fit. I wonder how much one of those things costs.
Old Apr 15, 2004 | 07:01 AM
neffster's Avatar
gte192t have you tried it? I watched a friend try it when I installed mine (kind of for fun because he's an AUDI and PORSCHE guy). It will not fit. The plenum mounting flange has the 4 holes drilled and tapped into it. The cover would have to "elongate" and "bend" to align with those mounting holes. The cover is not that plyable, therefore it will not work.
2004 Infiniti G35C-6MT
LR | Willow | Premium | Aero | Splash | BSM
30% Lumar Tint | Invinca Shield (C-Bra)
Z-Tube | JWT Pop Charger | RT Cats | Crawford Plenum | JIC Y-Pipe (STILL on order)
Old Apr 15, 2004 | 10:51 AM
z_with_back_seat's Avatar
You can put some spacers in there to not have it flex but it is still going to rub.
For a 350z cover it is a simple cut to match the leading edge of the plenum. The cut will go through the "V6" lettering. I back filled the letters as well as "3.5" ground down and wet sanded smooth before I painted. I did not want to rebadge my car Nissan so I filled the indent for the Nissan logo and put an Infiniti trunk logo on it. It might be a little work but it is much cleaner.
I also added some foam padding on the air scoop as the cover and the scoop will rub.
Hope that helps once you get the cover.
G35C - 6MT, DG/G, Aero, BSM, Flaps, Stillen Intake, Z tube, Crawford v5, 6 Wire Grounding Kit, Clear Corners, 2nd Battery (Brake) Cover, Sirius, Momo F16 Evo Shifter, 30% 3M Tint & more to go
Old Apr 15, 2004 | 02:48 PM
lowrider's Avatar
back_seat
Thanks for confirming my suspicion, I knew the "Zs" cover was longer, and I thought it might rub the center intake scoop. That's the reason I took the stock cover and cut it. I like the look, and so does's everyone who has seen it. Yours looks good too.
Lou
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
DRG35R
Sep 16, 2015 05:33 AM
