Idle after spacer/intake install
Old May 22, 2008 | 05:06 PM
Nappy's Avatar
I recently installed a Stillen Hi-flow intake kit and 5/16" plenum spacer. My idle isn't rough, but it's about 300 rpm lower than it used to be. From time to time I also have issues with it dying on startup unless I give it a little gas so it doesn't dip too low.
I'm guessing I have to do the ECU reset process, but I just saw someone mention MAF cleaner? What's the best route to take? Is that ECU reset pedal dance pretty simple to do?
Old May 22, 2008 | 05:42 PM
G35fromPA's Avatar
Follow the Idle air volume learning procedure - should be included w/the spacer. Or go to motordyne.com and download the manual.
Old May 22, 2008 | 09:03 PM
Hydrazine's Avatar
If you have a good idle then you have a good seal at the spacer.
Try reinstalling your stock air box. CAI's can sometimes cause stalling.
But as mentioned above, you may just need a idle air volume relearn procedure. Easy fix.
junon
Jan 14, 2023 09:37 PM
esotericrider
Feb 14, 2022 07:19 AM
Silver tiburon
Sep 4, 2015 07:17 PM
06gtfanatic
Aug 31, 2015 03:19 PM
ghost_g35
Aug 7, 2015 10:31 AM
