Any News On Nismo Intake?
Old Apr 20, 2004 | 07:37 PM
nitty917's Avatar
Does anyone have the Nismo Intake?
Old Apr 20, 2004 | 08:37 PM
subrobo's Avatar
Re: Any News On Nismo Intake?
Yeah, i got the Nismo intake! it sounds great at rpm over 4
Old Apr 20, 2004 | 08:44 PM
Meatshackle's Avatar
Deep Sea Moderator
There's a newer version out now, it works a lot better with the G. I have the old version, love it, and didn't have any problems installing it.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Apr 20, 2004 | 10:09 PM
GookusMaximus's Avatar
Could you explain in more detail please? I just got a Nismo CAI 2 days ago. If the new one just came out, I wonder which version I purchased. I'd be pissed if I got the old one.
G35 coupe (Jan ~ Feb)
6spd, Black/Tan
Premium Pkg.
Old Apr 20, 2004 | 10:22 PM
1crazmofo's Avatar
The new one has a single long pipe from the throttle body, eliminates needing to use the MAF body and uses the sensor inside the long tube...
Old Apr 20, 2004 | 10:25 PM
1crazmofo's Avatar
Another pic of the Generation II Nismo intake...
Old Apr 21, 2004 | 02:55 AM
richie's Avatar
how much was the 2nd gen Nismo intake??? how was the install on that puppy?
Old Apr 21, 2004 | 04:04 AM
nuttyprof's Avatar
so wheres the MAF? wtf? no MAF?
G35S 6MT / ts ecu / 350z springs & struts / jwt popcharger + z-tube / stillen dual exhaust / 6-wire ground kit / soon: kinetix high flow / ssr intake manifold
Old Apr 21, 2004 | 10:32 AM
1crazmofo's Avatar
The MAF is in tube underneath...You simply remove it from the original plastic MAF body and re-install in the provided slot on the tube...Install was not too bad, need to remove the wheel and wheel well cover to slide the filter down into position without damaging the filter (Very Fragile FIlter, DON'T DAMAGE IT by forcing it down there). I also cut the styrofoam insert behind the air slot so as to not block air and position the filter nicely, it is in the way if you don't cut it...
Here's the source for BEST price...
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
Old Apr 21, 2004 | 11:21 AM
1crazmofo's Avatar
One other install note...Make SURE that the MAF sensor is TIGHT inside the tube...THe screws from the MAF were just a hair too long and the MAF jiggled inside the tube with the screws completely tightened. I inserted high-temp rubber washers to make sure it sat firm in the tube...If it jiggles, it will get damaged and need to be replaced...VERY expensive part from Nissan...
Old Apr 21, 2004 | 01:12 PM
Mother F(*&$(*@#&(!!!!!!!!
How come nobody informed me of this a few days ago when I spent about $300 on the first gen Nismo CAI????? DAMN I'm PISSED!!!!
What else is different from the two CAIs in terms of sounds & Performance?
6spd, Black/Tan
Premium Pkg.
Old Apr 21, 2004 | 02:29 PM
subrobo's Avatar
I dont think there is any different, i got the first gen too, as seen from the pic...CAIs are alike...wont make any different...they will drop your power in low end and gain little bit at high. What i like is the sound of a CAI after 4rpm
Old Apr 21, 2004 | 02:44 PM
1crazmofo's Avatar
Performance will be the pretty much the same, it's more an appearance and installation upgrade than a functional one...
Just less connections and pieces....
Old Apr 21, 2004 | 03:37 PM
tgenius's Avatar
Nismo intake for a G35? Am I missing something, or is this a 350Z intake? does it work for the sedan?
2004 G35s 5AT DG/Graphite/Premium/Huper Optik Tint
Old Apr 21, 2004 | 04:47 PM
1crazmofo's Avatar
Yeah, it's the 350Z intake...SHOULD fit the Sedan no prob, but not sure about spacing down below...I'm pretty sure it will though
